Integral could lead to Hypergeometric function
The integral in question involves parameters a, b, c, and n, with a focus on its convergence properties. It has been established that the integral converges for certain values of n, which can be either positive or negative, but not for integer values. When b is set to zero, the integral simplifies to a form that leads to the hypergeometric function. Attempts to solve the integral using Mathematica have been unsuccessful when b is non-zero. The discussion suggests that partial fraction decomposition may be a viable approach to tackle the integral.
DMESONS
How can I perform this integral
\begin{equation}
\int^∞_a dq \frac{1}{(q+b)} (q^2-a^2)^n (q-c)^n ?
\end{equation}
all parameters are positive (a, b, and c) and n>0.
I tried using Mathemtica..but it doesn't work!
if we set b to zero, above integral leads to the hypergeometric function!
Mathematics news on Phys.org
Hi !
What do you think about the convergence, or not ?
JJacquelin said:
Hi !
Thanks for your comment.
The integral is convergent for some values of (n) which can be either positive or negative.
As I mentioned, if I set b =0, the result have the form of hypergeometric function!
But if b is not zero, Mathematica can't solve it.
\begin{equation}
\end{equation}
I'll preface this by asking what it is for, but I'll try to provide a partial solution, too.
To start, what on Earth is this for? We do we come up with such silly things to integrate?
Second, let's see if we can simplify things considerably:
$$\int\limits_{[a,+\infty)}\left(\frac{1}{q+b}(q^2-a^2)^n(q-c)^n\right)\mathrm{d}q=\int\limits_{[a,+\infty)}\left(\frac{1}{q+b}(q-a)^n(q+a)^n(q-c)^n\right)\mathrm{d}q.$$
I'm thinking we might just approach this by means of partial fractions. On cursory examination, I don't see a contour that would simplify things, so brute force might be necessary.
Hi !
Would you mind give a non contradictory wording of the question about the sign of n.
Hi !
For which value of (n) the integral is convergent ?
Clue : The integral is NOT convergent for any integer (n), either positive or negative or n=0.
Suppose ,instead of the usual x,y coordinate system with an I basis vector along the x -axis and a corresponding j basis vector along the y-axis we instead have a different pair of basis vectors ,call them e and f along their respective axes. I have seen that this is an important subject in maths My question is what physical applications does such a model apply to? I am asking here because I have devoted quite a lot of time in the past to understanding convectors and the dual...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
