How can I improve my back-scattered images with a scanning electron microscope?
The discussion revolves around challenges faced when using the Backscattered Electron Detector (BSED) on a scanning electron microscope, specifically when only faint dark images are produced. Key advice includes utilizing the auto-contrast/brightness feature to enhance image quality. It is noted that generating back-scattered images can be tricky due to factors such as the atomic weight of the sample, the positioning of the detector, and adherence to good imaging practices. Additionally, it is highlighted that doped silicon BSE detectors may operate slower than secondary electron detectors, suggesting that using slower scan rates could improve results.
bluetree
Hi,
I am working with a scanning electron microscope with the SED and it works fine. I have tried on several occasions to use the BSED without any success. All I get is a very faint dark image. Would you be able to give me some advice as to where I am going wrong?
Thanks in advance
Have you tries hitting the auto-contrast/brightness button?
Back-scattered images can be difficult to generate, and the signal depends heavily on the atomic weight of your sample, detector position, as well as general good imaging practices. Also, doped silicon BSE detectors tend to be slower than SE detectors, so using slower scan rates could help
