Counter torque, voltage and current
Counter torque in AC generators increases with high current production, while its relationship with voltage is complex; higher voltage may not necessarily decrease counter torque. Counter torque is directly related to counter EMF, as the induced voltage in the generator's armature causes current draw that generates a magnetic field opposing the source field, in accordance with Lenz's law. The minimum counter torque equals the output power divided by rotational speed, but actual torque is typically higher due to losses. Additionally, counter torque is influenced by the phase shift between voltage and current, affecting overall power. Understanding these relationships is crucial for efficient energy conversion in electrical machines.
Idea04
When an ac generator produces high current the counter torque increases, but if voltage increases would the counter torque decrease? Is counter torque related to counter EMF?
Counter torque is required by conservation of energy. Mechanical power is equal to the product of torque times rotational speed. Torque (in n-m) times rotational speed (in radian per sec) gives power in Watts.
Thus the minimum possible counter torque on a generator is equal to the output power divided by the rotational speed. Of course the actual torque is typically somewhat greater than this due to the presence of both electrical and mechanical losses.
is counter torque affected by voltage and current phase shift?
Yes, look at what I said above about power and counter torque. Since power can be influenced by all of those variables then the counter torque can be influenced too.
"is counter torque related to counter emf?"
Consider that when voltage is induced in the armature of the generator, a connected load will draw a current that creates a magnetic field which opposes the source magnetic field (lenz' law)
The more load connected (parallel) the lower the overall resistance. The current draw increases, and the magnetic field which opposes the source field is stronger.
The counter torque is the reaction between the source field (which induces voltage in the armature) and the field created by the armature current
Yeah, that's actually a very pertinent question.
Not all machine models include an internal "back" EMF (induction motor for example), but for those that do (synchronous and DC machines for example) the energy flowing in/out of this internal EMF is precisely the energy being converted (from/to electrical to/from mechanical).
So yes, this counter EMF (or more particularly the power in this EMF) is extremely closely connected with the counter torque. Specifically it is this power, which when divided by the rotational speed, gives precisely the counter torque.
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
I am not an electrical engineering student, but a lowly apprentice electrician. I learn both on the job and also take classes for my apprenticeship. I recently wired my first transformer and I understand that the neutral and ground are bonded together in the transformer or in the service. What I don't understand is, if the neutral is a current carrying conductor, which is then bonded to the ground conductor, why does current only flow back to its source and not on the ground path...
