Looking for comprehensive list (or link) of even power summations
The discussion centers on a function that calculates exact values for even powered summation series but produces incorrect results for powers of '2' and '12+'. The user seeks a comprehensive list of power summations in the form of the Riemann zeta function for even powers greater than ten. They mention that while their function correctly computes values for lower even powers, discrepancies arise for higher powers, particularly for '12' and beyond. The conversation also highlights the relationship between Bernoulli numbers and zeta values, as well as the need for further exploration to resolve the inaccuracies in the function's outputs. The user expresses intent to refine their function and share updates once resolved.
mesa
I have a function that results in 'exact' values for even powered summation series but it gives odd results for powers of '2' and '12+', how exciting! Unfortunately this also means the function is a far cry from a 'general solution'...
Does anyone have a comprehensive list of power summations in the form of,
$$\sum_{n=1}^{\infty} 1/n^m$$
where 'm' is greater than the 10th power in exact form? (even of course)
Mathematics news on Phys.org
That's just \zeta(m). The Bernoulli numbers can be calculated explicitly and can be written in terms of zeta values, see
http://en.wikipedia.org/wiki/Bernoulli_numbers#Asymptotic_approximation
for the relationship between Bernoulli numbers and zeta values, and
http://en.wikipedia.org/wiki/Bernoulli_numbers#Explicit_definition
for a formula for calculating them. I also found this page
http://www.fullbooks.com/The-first-498-Bernoulli-Numbers.html
which says it has a list of the Bernoulli numbers but you might want to check that it is correct.
It's not clear what your post means when you say you have a function that results in exact values, but gives results that you think are wrong for almost all powers - in what manner is it supposed to be exact?
The derived function will compute exact values of 'some' even powered summations. At the moment it will produce correct answers for,
$$\sum_{n=1}^{\infty} \frac{1}{n^4}=\frac{Pi^4}{90}$$
$$\sum_{n=1}^{\infty} \frac{1}{n^6}=\frac{Pi^6}{945}$$
$$\sum_{n=1}^{\infty} \frac{1}{n^8}=\frac{Pi^8}{9450}$$
$$\sum_{n=1}^{\infty} \frac{1}{n^{10}}=\frac{Pi^{10}}{93555}$$
But for powers of '12' and higher the results don't look right and I know '2' is also incorrect (It is giving Pi^2/20, not Pi^2/6). I can easily fix the '2' but I need to see what is going on with the other end since it is best to work both sides of the problem.
I could post the function although it is incomplete as far as being a 'general solution'. These discrepancies can likely be fixed but in order to do so I need a more comprehensive list of exact values for these power summations.
On another note, thanks for the links!
Hey Office_Shredder, I had a chance to run through these links although I am not clear on what this has to do with the question I posed, am I missing something or was my post just a little too hazy and that led you off track?
The first link gives the formula
B_{2m} = (-1)^{m+1} \frac{2 (2m)!}{(2\pi)^{2m}} \left( \sum_{n=1}^{\infty} 1/n^{2m} \right)
which can be solved to give
\sum_{n=1}^{\infty} 1/n^{2m} = (-1)^{m+1} B_{2m} \frac{ (2\pi)^{2m}}{2(2m)!}
So to calculate your sum on the left you need to evaluate the thing on the right, which is easy except for the B2m[/sum] part. I gave a link that will let you explicitly calculate it as a formula (if you wanted to compare your formula to the formula for the B's) and also a link which gives numerical evaluations of the first couple hundred.
For example, from the last link B36 = -26315271553053477373/1919190, so letting m=18 above,
\sum_{n=1}^{\infty} 1/n^{36} = 26315271553053477373/1919190 * \frac{ (2\pi)^{36}}{2(36)!}
We can confirm these are in fact the same number.
http://www.wolframalpha.com/input/?i=zeta(36)
http://www.wolframalpha.com/input/?i=+26315271553053477373/1919190+*+\frac{+(2\pi)^{36}}{2(36)!}
Okay, it all makes sense now. I didn't notice in that first link to wikipedia that it was a summation for the far right term. Sometimes being so focused it is hard to spot even the obvious...
I am pleased to see that,
\sum_{n=1}^{\infty} 1/n^{12} = \frac{ 691Pi^{12}}{638512875}
I 'threw out' my solution as being anomalous because it had a 'non 1' numerated fraction for an answer (just like this does). I unfortunately left my notebook at home (probably crumpled up buried under a pile of sheets and pillows :P) although I will check this once I get home.
So if this is in fact a 'general solution' then it is also a unique version of this Riemann Zeta function that doesn't require an input of your Bernoulli numbers, neat! (That is of course assuming the solutions for powers of 12+ are correct...)
Office_Shredder, okay I checked it. The correct answer for n=12 is,
$$\sum_{n=1}^{\infty} 1/n^{12} = \frac{ 691Pi^{12}}{638512875}$$
My function gives,
$$\sum_{n=1}^{\infty} 1/n^{12} = \frac{ 733Pi^{12}}{638512875}$$
Close but not correct. I will work this from both ends and post when I have a solution. Thanks for the help.
