Thermodynamics? number crunching thermal conductivity
The discussion focuses on calculating heat transfer from polyethylene (PE) pipe, specifically converting thermal conductivity from W/(m·C) to BTU/(hr·ft·F). The thermal conductivity of the PE pipe is approximately 0.46 W/(m·C), which converts to about 0.266 BTU/(hr·ft·F). To determine the heat load (Q) for 10 square feet of PE pipe with a temperature difference (dT) of 10°F, the formula Q = k/d * ΔT * A is suggested, where k is the thermal conductivity and d is the wall thickness. The wall thickness of 0.120 inches must be converted to feet for accurate calculations. The final calculation indicates that using the correct units leads to a heat transfer rate of approximately 2.22 BTU/hr per square foot per degree Fahrenheit.
fastline
I am working on some basic calcs for heat transfer from polyethylene pipe. My numbers are not working out right so I need a little refresher.
The PE pipe would have a TC of about .46 W/(m.*C). to get to BTU/(hr.ft.*F), I mult by .5779 to get .266.
Assuming 10sf of PE pipe, and let's say a dT of 10*F, how do I arrive at my BTU/hr? Wall thickness of piping is .120" but I am told that does not matter. IIRC, the unit is actualy per sf PER ft so I might actually divide by my thickness which gets me closer at around 2.22 BTU/hr/sf*F of pipe?
Science news on Phys.org
The formula for the heat load Q (BTU/hr) is:
Q=\frac{k}{d}ΔTA
where d is the wall thickness.
I guess I am second guessing the units here. Would you mind applying the math to my above figures? Would this indeed be
k=.266
d=.120
k/d = 2.22BTU?
k=.266
d=.120
k/d = 2.22BTU?
You need to use d expressed in feet. How many inches are there in 1 ft?
Thread 'Thermo Hydrodynamic Effect'
Vídeo: The footage was filmed in real time. The rotor takes advantage of the thermal agitation of the water. The agitation is uniform, so the resultant is zero. When the aluminum cylinders containing frozen water are immersed in the water, about 30% of their surface is in contact with the water, and the rest is thermally insulated by styrofoam. This creates an imbalance in the agitation: the cold side of the water "shrinks," so that the hot side pushes the cylinders toward the cold...
