Delta v and change in velocity
The discussion centers on the change in kinetic energy when a 5 kg object's velocity decreases from 5 m/s to 4 m/s. Participants debate whether the change in kinetic energy is -22.5 J or +22.5 J, emphasizing that "change" typically refers to final velocity minus initial velocity. There is confusion about whether the question pertains to the object's kinetic energy or the energy absorbed by another entity. Clarification is requested regarding the full context of the problem, as it influences the interpretation of the energy change. The conversation highlights the importance of understanding the relationship between velocity changes and kinetic energy calculations.
Miraj Kayastha
If the velocity of the object of 5 kg changed from 5 m/s to 4 m/s. Then is the change in kinetic energy -22.5 J or +22.5J.
doesn't change mean final velocity minus initial velocity?
Miraj Kayastha said:
If the velocity of the object of 5 kg changed from 5 m/s to 4 m/s. Then why isn't the change change in kinetic energy -22.5 J. The correct answer is +22.5J.
This is vague. This is obviously from a HW/Coursework question, which you are not telling us. The "change" depends on the OBJECT IN QUESTION. Is this really the change in KE of the object that slowed down, or the change in KE of another entity that absorbed this energy change? Without you giving us the full picture, we can't tell.
If this is related to school work, please continue by presenting the full question, and what you have attempted, in the HW/Coursework forum.
Zz.
Well, does the KE of the object increase or decrease?
Change in any quantity generally means 'final value' - 'initial value'.
Hi there, im studying nanoscience at the university in Basel. Today I looked at the topic of intertial and non-inertial reference frames and the existence of fictitious forces. I understand that you call forces real in physics if they appear in interplay. Meaning that a force is real when there is the "actio" partner to the "reactio" partner. If this condition is not satisfied the force is not real. I also understand that if you specifically look at non-inertial reference frames you can...
This has been discussed many times on PF, and will likely come up again, so the video might come handy. Previous threads: https://www.physicsforums.com/threads/is-a-treadmill-incline-just-a-marketing-gimmick.937725/ https://www.physicsforums.com/threads/work-done-running-on-an-inclined-treadmill.927825/ https://www.physicsforums.com/threads/how-do-we-calculate-the-energy-we-used-to-do-something.1052162/
I have recently been really interested in the derivation of Hamiltons Principle. On my research I found that with the term ##m \cdot \frac{d}{dt} (\frac{dr}{dt} \cdot \delta r) = 0## (1) one may derivate ##\delta \int (T - V) dt = 0## (2). The derivation itself I understood quiet good, but what I don't understand is where the equation (1) came from, because in my research it was just given and not derived from anywhere. Does anybody know where (1) comes from or why from it the...
