Is There a General Theorem for the Sum or Difference of Terms^n?
  • Thread starter Thread starter Jhenrique
The discussion explores the existence of a general theorem for the sum or difference of terms raised to the power of n, particularly focusing on binomials. It highlights that the expression (x^n - y^n) can be factored as (x - y)(x^(n-1) + x^(n-2)y + ... + y^(n-1)), which is a foundational result in algebra. The conversation also touches on the sum of a geometric series and its relation to these expressions, particularly when x is less than 1 and n approaches infinity. Additionally, specific formulas for sums of cubes and higher odd powers are mentioned, with a note that a formula for sums involving three variables is not widely recognized. The discussion emphasizes the importance of deriving generalizations through specific examples and careful observation.
Jhenrique
Binomials
I was verifying that \\x^2-y^2=(x-y)(x+y) \\x^3-y^3=(x-y)(x^2+xy+y^2) and I realized that can there is a formulation more general like the theorem binomial... my question is: exist a general theorem for sum or difference of terms^n ?
Mathematics news on Phys.org
You can always proceed with the division of x^n-y^n by x-y.
Then you can guess and then demonstrate what the general solution is.
For example:
(x^11 - y^11)/ (x - y) =
x^10 + x^9 y + x^8 y^2 + x^7 y^3 + x^6 y^4 + x^5 y^5 + x^4 y^6 + x^3 y^7 + x^2 y^8 + x y^9 + y^10
Try to be specific and by considering multiple examples, you can often find the path to a generalization.
Never try to be general too early.
(xn - yn) = (x - y)(xn-1 + xn-2y + xn-3y2 + ... + yn-1)
is considered fairly elementary, but often useful. It is fairly easy to see it is true if you just multiply the x of the first bracket by the second bracket on one line and -y from the first bracket by the second bracket on the second line you will see.
A connection you should not fail to observe is that this gives you the answer to getting the sum of a geometric series which is
1 + x + x2 + xn-1
(I have made the final term xn for easy comparison, but you you'll be able to see what the sum is if the final term is xn).
The most useful of all applications of this is when x < 1 and n is infinite.
Likes 1 person
Very good!
And which the formula for xn + yn and for xn + yn + zn?
Jhenrique said:
Very good!
There is a well-known formula for x3 + y3 (= (x + y)(x2 - xy + y2), and formulas for higher odd powers of xn + yn are fairly well known. Hint: one factor is x + y. You can get the other factor by long division.
If there's a formula for xn + yn + zn I'm not aware of it.
Suppose ,instead of the usual x,y coordinate system with an I basis vector along the x -axis and a corresponding j basis vector along the y-axis we instead have a different pair of basis vectors ,call them e and f along their respective axes. I have seen that this is an important subject in maths My question is what physical applications does such a model apply to? I am asking here because I have devoted quite a lot of time in the past to understanding convectors and the dual...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
