Understanding Enthalpy of an Ideal Gas: Effects of Temperature and Pressure
  • Thread starter Thread starter alighazanfer25
    Gas Ideal gas
The discussion revolves around the enthalpy of an ideal gas, specifically examining how temperature and pressure affect it. Participants explore theoretical aspects, definitions, and implications of enthalpy as a state function, while also considering specific scenarios such as isothermal processes and phase transitions.
  • Some participants assert that enthalpy of an ideal gas is a function of temperature only, suggesting that changes in pressure do not affect enthalpy if temperature is held constant.
  • Others argue that enthalpy is a state function that can only be measured at constant pressure, and that changes in internal energy and volume are also relevant to changes in enthalpy.
  • One participant presents equations relating internal energy and enthalpy, indicating that for an ideal gas, enthalpy can be expressed in terms of temperature alone if the number of particles is constant.
  • There is a discussion about isothermal processes, where some participants claim that changing pressure without changing temperature does not affect enthalpy, while others challenge this view by questioning the implications of the ideal gas laws.
  • A participant raises a question about whether quantum tunneling can be considered a form of enthalpy change, introducing a speculative angle to the discussion.
  • Several participants clarify that under certain conditions, such as compression, the temperature may not necessarily rise, which complicates the relationship between pressure and enthalpy.
Participants express differing views on the relationship between pressure, temperature, and enthalpy, with no clear consensus reached. Some maintain that enthalpy is solely a function of temperature, while others emphasize the role of pressure and internal energy changes.
There are unresolved questions regarding the implications of the ideal gas laws in various scenarios, particularly in isothermal and isobaric processes. The discussion also highlights the complexity of thermodynamic variables and their interdependencies.
alighazanfer25
I have read that enthalpy of an ideal gas is a function of temperature only, I am having a little trouble getting it.
Consider a cylinder filled with an ideal gas so if we increase the pressure by pushing the piston down on it , a/c to ideal gas equation the temperature also rises, which in return must increase the enthalpy , so haven't we changed enthalpy by changing pressure?
Enthalpy is a state function where only PV is allowed to do work. The only way to measure enthalpy is at constant pressure. H<0 exothermic, H>0 endothermic. Exothermic and endothermic is the heat exchange though the container to the outside environment. exothermic is heat absorbed from the outside environment, vise versa for endothermic.
The only way to measure a change in enthalpy is at a specific thermodynamic state.
a state function refers to a property of the system that depends only on its present state. This article will help
http://memo.cgu.edu.tw/hsiu-po/chemistry/lecture 6.pdf
Enthalpy is H=E+PV. For an ideal gas, E is dependent on the number of particles and the temperature only. By application of the equipartition theorem and the kinetic theory of particles, one finds:
$$E=\frac{f}{2}NkT$$
Additionally, we know the ideal gas law:
$$PV=NkT$$
Giving us immediately:
$$H=\frac{f+2}{2}NkT$$
Which is dependent, if N is constant, on only the temperature.
Your confusion arises from the fact that there are often too many thermodynamic variables, more than required to define the state of the system. This is why we have equations of state relating some of the variables to others.
For an ideal gas, for example, we cannot independently change T, N, V, and P at the same time, and so T, N, V, and P are not independent variables.
When we make statements such as "X is dependent only on the temperature", we usually mean we can determine X, if you only give us the temperature. Changes in other thermodynamic variables can of course change X, but the change will most readily manifest as a change in T.
So , we can change any other variable as long as Temp. is constant the enthalpy won't change , like if we change pressure isothermally don't effect 'H' of an ideal gas. Am I right?
not quite, let's try this definition
Enthalpy is the amount of heat content used or released in a system at constant pressure. Enthalpy is usually expressed as the change in enthalpy. The change in enthalpy is related to a change in internal energy (U or E) and a change in the volume (V), which is multiplied by the constant pressure of the system.
From the above definition you can see that pressure is constant. Isothermal heat exchange is a change in entropy, however a change in temperature will change the internal energy (E or U) and will result in a change in entropy. Now some examples of various types of entropy change
When a process occurs at constant pressure, the heat evolved (either released or absorbed) is equal to the change in enthalpy. Enthalpy is a state function which depends entirely on the state functions T, P and U. Enthalpy is usually expressed as the change in enthalpy, energy is a state function, but work and heat are not state functions
\Delta H=\Delta E+\Delta PV
If temperature and pressure remain constant through the process and the work is limited to pressure-volume work, then the enthalpy change is given by the equation:
\Delta H=\Delta E+ P \Delta V
Also at constant pressure the heat flow (q) for the process is equal to the change in enthalpy defined by the equation:
H=q
When the temperature increases, the amount of molecular interactions also increases. When the number of interactions increase, then the internal energy of the system rises. According to the first equation given, if the internal energy (U) increases then the change of enthalpy increases as temperature rises.
Also you can have enthalpy of phase transitions, such as,
1)enthalpy of vaporization/condensation
2)enthalpy of fusion/freezing
3)enthalpy of sublimation
all three are at constant pressure, The enthalpy change of a reverse phase transition is the negative of the enthalpy change of the forward phase transition.
edit:forgot to mention the heat exchange is either exothermic or endothermic depending on the direction of the heat exchange, see post 2
I just thought of a curious question myself on enthalpy change. Is quantum tunneling a form of enthalpy change?
The ideal gas equation does not predict that the temperature must rise. If we compress the gas, then the volume will decrease and the pressure will correspondingly rise. The temperature can be held constant by removing heat. Under the these conditions, the enthalpy is constant.
So, if you increase the pressure holding the temperature constant, the enthalpy will not rise. So, enthalpy of an ideal gas is not a function of pressure.
Chet
I am assuming what you are referring to, Chet is the case in the compression-condensation stage of a heat pump. I'm curious to know how the ideal gas laws remain valid in this situation? How can the process be isochoric and isobaric while still undergoing a temperature change?
No. I was referring to a plain old ideal gas. Nothing more.
How can you increase the temperature of the gas while the pressure and volume remain constant? Wouldn't that be violating the ideal gas laws?
Yes.
(∂H/∂v) at constant T for an ideal gas is zero correct? Because there is no temperature change, there will be no change in enthalpy?
Yes.
  • · Replies 33 ·
  • · Replies 60 ·
10K
  • · Replies 35 ·
