Mass radius relationship for SIRIUS B
The discussion centers on the mass-radius relationship of white dwarf stars, specifically SIRIUS B, and the implications of the Chandrasekhar limit. A formula for the radius-mass relationship in non-relativistic Fermi gas is presented, yielding R=3.58*10^16 M^(-1/3). For relativistic Fermi gas, the maximum mass limit is established at 1.44 solar masses, but confusion arises regarding how to plot the radius versus mass graph since the radius appears to cancel out. The conversation clarifies that the correct relationship bridging non-relativistic and relativistic limits is represented by a more complex "green curve," which incorporates full expressions for momentum flux and kinetic energy density. Ultimately, understanding these distinctions is crucial for accurately plotting the mass-radius relationship in white dwarfs.
cooper607
hi guys, I have been doing a research on white dwarf stars and chanrashekhar limit. I need to plot a graph for the mass-radius relationship of the dwarfs. from the equalization of the hydrostatic equilibrium pressure and the electron degeneracy pressure I found out the radius -mass relationship for non relativistic fermi gas.
my final result is
but when I take relativistic fermi gas, pressure comes in order of 4/3 and the radius cancels out leaving the equation to be
M(limit)=1.44 M(sun)
Now for this maximum limit how can I plot a graph for radius vs mass. which values should i input for different masses? please help me
Astronomy news on Phys.org
What do you mean plot a graph of radius vs mass for a limit? The limit is one value. It's a dot. What is the radius at this mass? If your final result is correct, you need only input this M(limit) into M.
But the relativistic fermi gas plot is different than the non relativistic, i want to know how do they get this graph?
dear Chronos, I actually visited that page earlier, for relativistic fermi gas they derived the relation to be 1=M^(-1/3) , so radius actually cancels out from both sides. so how do they plot that graph where radius is zero when mass goes to 1.44? i didnt get any expression for the graph..can you tell me if there is any radius -mass relation for the relativistic curve ?
The "relativistic curve" must really mean the "completely correct curve that bridges between the nonrelativistic and relativistic limits." So those two limits are the easy calculations, because the kinetic energy per particle is either p2/2m, or is pc. That gives the the blue and red curves respectively, but those are only true at the edges of the plot. The green curve is the correct curve, which uses the fully correct expressions for the momentum flux that goes into pressure, and the kinetic energy density. In units where momentum is measured in mc units, those expressions are, the angle-averaged momentum flux that goes into the isotropic pressure is 1/3 (from the angle averaging) times p2/root(1+p2), and the kinetic energy is root(1+p2)-1. If you use those two expressions, you obtain the green curve, which is correct in all limits. So the confusion is about whether "relativistic" means "including relativistic corrections" versus "taking the ultrarelativistic limit." They mean the former with that green curve.
This thread is dedicated to the beauty and awesomeness of our Universe. If you feel like it, please share video clips and photos (or nice animations) of space and objects in space in this thread. Your posts, clips and photos may by all means include scientific information; that does not make it less beautiful to me (n.b. the posts must of course comply with the PF guidelines, i.e. regarding science, only mainstream science is allowed, fringe/pseudoscience is not allowed). n.b. I start this...
Asteroid, Data - 1.2% risk of an impact on December 22, 2032. The estimated diameter is 55 m and an impact would likely release an energy of 8 megatons of TNT equivalent, although these numbers have a large uncertainty - it could also be 1 or 100 megatons. Currently the object has level 3 on the Torino scale, the second-highest ever (after Apophis) and only the third object to exceed level 1. Most likely it will miss, and if it hits then most likely it'll hit an ocean and be harmless, but...
