Electricity generated using an armature
  • Thread starter Thread starter stu1984
    Electricity
An easy equation to calculate the energy generated from spinning an armature is not straightforward due to several influencing factors, including magnet strength, distance from magnets to coils, number of windings, RPM, and wire gauge. The strength of the magnets decreases exponentially with distance, complicating calculations. To successfully charge a battery, the generated voltage must exceed the battery's no-load float voltage, with the relationship between voltage and current being non-linear. Building a test rig is recommended to obtain practical results rather than relying solely on theoretical calculations. This approach aims to determine the feasibility of charging a battery with the generated electricity.
stu1984
Is there an easy equation to calculate the energy generated from spinning an armature. I was wondering if there was such an equation where I could enter the following inputs:
• number of rotations on the shaft
• the number & size of the magnets being used
• the length and thickness of the wire surrounding
…to get an output of the energy generated.
Ultimately I want to understand if it is possible to re-charge a battery (battery to be decided on) with electricity generated from this process.
Or if there are any useful websites or books anyone knows of
All information will come gratefully, I thank you in advance.
Regards
Stu
You will have a few factors that determine the generation of electricity, starting with:
Strength of magnets
Distance from magnets to coils
Number of windings in coils
RPM
Wire gauge in coils
The first two are quite important and going to be difficult to plug into a simple equation. The strength is going to fall off on an exponential curve based on distance.
In order to charge a battery, you need to maintain a voltage higher than the no-load float voltage. As you increase this voltage more then more current will flow into the battery and charge it faster while also heating it (via the internal ESR). But this is similar to the discharge curve where its not a linear relationship.
It would seem to be far easier to build a test rig then to try to calculate and end up off an order of magnitude from a poor assumption.
Thank you,
i am currently trying to asemble the components for a test. this will bring the result hopefully required to charge a battery
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
I am not an electrical engineering student, but a lowly apprentice electrician. I learn both on the job and also take classes for my apprenticeship. I recently wired my first transformer and I understand that the neutral and ground are bonded together in the transformer or in the service. What I don't understand is, if the neutral is a current carrying conductor, which is then bonded to the ground conductor, why does current only flow back to its source and not on the ground path...
