Magnetic flux outside cylindrical conductor
mmh37
Hey everyone,
I have failed to show that the magnetic flux outside a cylindrical conductor is zero.
The problem goes like this:
a coaxial cable consists of a solid inner cylindrical conductor of radius a and an outer cylindrical conductor of inner and outer radius b and c. Distributed currents of equal magnitude I flow in opposite directions in the two conductors. Derive expressions for the magnetic flux density B(r) for each of these regions
1) 0<r <a
by amperes law I showed: B = \frac {K *l*r} {2*pi*a^2}
where K is the permeability of free space, don't know how to write that with latex
2) a<r<b
again by amperes law: B = \frac {K *l} {2*pi*r}
3) b<r<c
again by amperes law: B = \frac {K *l*(r^2-b^2)} {2*pi*r*(c^2-b^2)}
4) c<r
I got stuck here, surely it must be zero...but how can that be shown?
thanks for your help - it's very much appreciated
With the coaxial cable coming out of the paper at you, draw a circular closed path around the outside of it.
INTEG[B dot dL] around that closed path = mu * I(enclosed)
The total I enclosed by the circle is zero, since the current up the inner conductor is the same as the current down the outer conductor, so B (or H) has to be identically zero everywhere outside the coax.
Edit -- BTW, check your answer for (3). When r=c, you should get zero for H.
Thanks Berkeman - that's explained it and it's very much appreciated! :-) As for the third one it surely has to be (c^2-r^2)/(c^2-b^2)
