Explanation of Eq of Peskin's Intro to QFT Book
beta3
Hi
Can someone please explain to me Eq 2.30 in Schroeder's and Peskin's book? (page 21)
how does he simplify the long equation of the commutator to this delta distribution?
\imath\delta^(^3^)\ (x - x')
Thanks
He starts with:
[a_{\textbf p},a_{\textbf p'}^{\sp\dagger}]=(2\pi)^3\delta^{(3)}(\textbf p-\textbf p')
This means that:
[a_{-\textbf p}^{\sp\dagger},a_{\textbf p'}]-[a_{\textbf p},a_{-\textbf p'}^{\sp\dagger}]=-2(2\pi)^3\delta^{(3)}(\textbf p+\textbf p')
Substituting this in and integrating over the delta function (i.e. replacing p with -p'), you get:
i\int \frac{d^3p'}{(2\pi)^3}e^{i\textbf p'(\textbf x'-\textbf x)}
which is just i times the inverse Fourier transform of e^{i\textbf p'\textbf x'}:
[\phi(\textbf x),\pi(\textbf x')]=i\delta^{(3)}(\textbf x-\textbf x')
thanks, but there's one thing i still don't understand
after substituting it in and then if you integrate, what happens to the term
\sqrt{\frac{\omega_p_'}{\omega_p}}
since p = p' (where by p I mean the magnituide of the three-vector), the two omegas are equal.
Pat
Pat
ah, yeah, now everything makes sense
Thank you two both soo much :wink:
Hello everyone, I’m considering a point charge q that oscillates harmonically about the origin along the z-axis, e.g. $$z_{q}(t)= A\sin(wt)$$ In a strongly simplified / quasi-instantaneous approximation I ignore retardation and take the electric field at the position ##r=(x,y,z)## simply to be the “Coulomb field at the charge’s instantaneous position”: $$E(r,t)=\frac{q}{4\pi\varepsilon_{0}}\frac{r-r_{q}(t)}{||r-r_{q}(t)||^{3}}$$ with $$r_{q}(t)=(0,0,z_{q}(t))$$ (I’m aware this isn’t...
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
