Melting Points of Iron Oxide, Aluminum, Baking Soda, Table Salt & Gas Stove Heat
Iron oxide melts at approximately 1,600°F, aluminum at around 1,221°F, baking soda at about 1,440°F, and table salt at roughly 1,474°F. A conventional US gas stove can reach temperatures between 400°F to 500°F. Aluminum foil is indeed made from pure aluminum, typically produced in thin sheets for flexibility. For detailed melting points and other chemical properties, resources like the CRC Handbook or Chemfinder can be useful. Overall, understanding these temperatures is essential for various cooking and industrial applications.
hediki
hello there about wat temp does ,Iron oxide, aluminum, baking soda, table salt melt? degress F please. and about how hot does a US conventional gas stove get? thanks. and aluminum foil is pure aluminum right?
any1 please i just need some info.
try looking through a CRC handbook or register for free at http://www.chemfinder.com and search there.
Google is always your best friend :)
Try wikipedia.org also
From Wikipedia, article Aluminum Foil:
Aluminum foil (Aluminium foil in Commonwealth English) is aluminum prepared in thin sheets (on the order of 0.02 mm in thickness). As a result of this, the foil is extremely pliable, and can be bent or wrapped around objects with ease. Aluminum foil is sometimes known as al-foil or alu-foil. It is also often called tinfoil, although it is not made from tin; or in North America, as Reynolds wrap after Reynolds Metals Company, the leading manufacturer when it was introduced on the American market (Much to the chagrin of Alcoa, Reynolds main competitor, which had its brand "Alcoa Wrap" referred to as "Alcoa Reynold's Wrap").
Aluminum foil typically has a highly reflective side and a more matte side. This is a result of common manufacturing processes. As aluminum foil is easy to tear, the foil is sent through machines in pairs. The side where the aluminum foil was in contact with the other sheet is more matte than the exterior side.
