First order differential equation help
xman
i've derived the following differential eqn from a problem I'm working on, and i have tried in vain to solve this if anyone can give a direction where i should go our how to attack would be greatly appreciated. the eqn is
I\,r= -L\dot{I}+\frac{3}{2}\mu_{0}m R^{2}\frac{z \dot{z}}{\left(R^{2}+z^{2}\right)^{5/2}}
where r,L,m,\mu_{0},R,\dot{z} are all constants. one of two ways I've tried solving this, was since
\dot{z}=const.\Rightarrow z=\dot{z}t
which just gives a particular solution i cannot find a solution for. the homogeneous part is quite trivial with the solution being
I_{homogeneous}=const. \, \exp(-rt/L)
am i missing something, is there another way. any help please
If L = 0, then if r = 0, I can be anything. If r is not zero, then I is just the right side divided by r. So we may assume L is nonzero. Let A = 1.5μ0mR²(z'³L)-1, B = R/z', D = r/L
I' + DI = At/(B² + t²)5/2
The solution to the homogenous equation is, as you know IH = Ce-rt/L. So you just need a particular solution. See if this helps at all.
thanks for the cite reference, i checked it out, and it's similar information i have in my old ode book in front of me. the integral you get with this
\int e^{Dt}\frac{At}{(B^{2}+t^{2})^{5/2}}dt
doesn't seem to be able to be integrated. i think this particular ode might need numerical methods to solve.
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
