Understanding Matter: Quark Transfer and Neutrino Differences
  • Thread starter Thread starter Sasa
Sasa
when we are dealing with matter could it not be postulated that
it is indeed the transfer of quarks that are causing the formation
of antiparticles (and the conversion of protons to neutrons) within the nucleus?
When dealing with neutrinos and anti neutrionos what, apart from the
need to balance the formula really separates the two?
it is not theorized that photons are their own antiparticles?
:confused:
The formation of anti-particles within the nucleus? Could you explain what you mean by this? Do you mean the positron emmision from the \beta^+ decay?
\beta^+ decay in the nucleus (the process which accounts for the conversion of protons to neutrons in the nucleus- which cannot happen in free space) is mediated by the weak force.
The particle that is seen after a neutron decays to a proton that accompanies the electron is simply named the electron anti-neutrino and the particle the emission of a positron (often called \beta^+ in nuclear physics) from a nucleus is called a electron neutrino. I don't really know if there is truly a way to tell them apart other than that. That is to say, do they interact differently (you could probably use them in some sort of scattering experiment and see how they interact).
And yes the photon is its own anti-particle.
I think you may simply be caught up in the use of the prefix "anti". The anti-particle has the same mass as its non-anti partner, it just has the opposite charge for all quanutm numbers they carry. Since the world is awash in electrons, we consider them the matter and we call the positron the anti-matter. But we could have easily decided that the electron was the antipositron. No problem there.
Where are these "quarks" in leptons?
Zz.
What is meant by "transfer of quarks"?
It is believed/theorized that a quark is "transformed" in positron (e+[/sub]) emission, or beta decay.
For beta decay in which a neutron transforms to a proton, electron and anti-neutrino, see http://hyperphysics.phy-astr.gsu.edu/Hbase/particles/proton.html#c3
See also - Transformation of Quark Flavors by the Weak Interaction
http://hyperphysics.phy-astr.gsu.edu/Hbase/particles/qrkdec.html#c1
Feynman Diagrams for Weak Force
http://hyperphysics.phy-astr.gsu.edu/Hbase/forces/funfor.html#c4
Sasa, if your thread is deleted, it is unwise to create the same thread under another username.
To repeat myself from last night, I think it is the interaction of quarks that is the cause of the strong nuclear force, I do not know what you mean by "transfer of quarks", either.
