Force Acting on Charge on Metal Ball: Irodov Problem 3.69
  • Thread starter Thread starter -marko-
    Irodov
-marko-
A metal ball or radius R=1.5[cm] has a charge q=10e-6[C]. Find the modulus of the vector of the resultant force acting on a charge located on one half of the ball.
I found a solution on http://irodov.nm.ru/3/resh/3_69.gif but I don't understand explanations regardind to the problem so I would appreciate if anyone could explain a solution.
You need to show your work before you get help.
Which part of the solution are you stuck in?
The whole problem is a little bit fuzzy to me (E', Eokp, E and relations between them), so it would be very helpful if you could explain main steps in solving this problem (without doing integration, just basic steps and formulae).
Thanks.
1. Find E using Gauss's law.
2. E_z=Ecos\theta=Qrcos\theta/R^3.
3. Integrate E_z\rho over the hemisphere.
Hello everyone, I’m considering a point charge q that oscillates harmonically about the origin along the z-axis, e.g. $$z_{q}(t)= A\sin(wt)$$ In a strongly simplified / quasi-instantaneous approximation I ignore retardation and take the electric field at the position ##r=(x,y,z)## simply to be the “Coulomb field at the charge’s instantaneous position”: $$E(r,t)=\frac{q}{4\pi\varepsilon_{0}}\frac{r-r_{q}(t)}{||r-r_{q}(t)||^{3}}$$ with $$r_{q}(t)=(0,0,z_{q}(t))$$ (I’m aware this isn’t...
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
