How can I calculate the eigenvalues of a Hamiltonian with spin 1/2 objects?
JohanL
Find the eigenvalues of the hamiltonian
<br /> H=a(S_A \cdot S_B+S_B \cdot S_C+S_C \cdot S_D+S_D \cdot S_A)<br />
where S_A, S_B, S_C, S_D are spin 1/2 objects
_________________________
I rewrite it as
<br /> H=(1/2)*a*[(S_A+S_B+S_C+S_D)^2-(S_A+S_C)^2-(S_B+S_D)^2]<br />
then i define
<br /> J_1=S_A+S_B+S_C+S_D<br />
<br /> J_2=S_A+S_C<br />
<br /> J_3=S_B+S_D<br />
and uses
<br /> J^2_i |j_1j_2j_3;m_1m_2m_3&gt; = (h^2) j_i(j_i+1)|j_1j_2j_3;m_1m_2m_3&gt;<br />
which gives the energies
<br /> E(j_1,j_2,j_3)=(h^2/2)*a*[j_1(j_1+1)-j_2(j_2+1)-j_3(j_3+1)]<br />
Where j_1 is addition of four angular momentum of 1/2 which gives it values of 0 1, 2 and in the same way j_2 and j_3 have values of 0 1.
Am i doing this the right way? It doesn't feel so :smile:
From the structure of your hamiltonian it almost looks like you could adapt transfer matrix methods, unless your spin things are vectors (I'm not clear on that). I would also say that there are restrictions on j_2 and j_3 based on j_1, but the thought process seems right.
Your method is completely correct. Just include the a.
Did it just seem too easy?
Thank you. Yes it seemed too easy :smile:
How about the degeneracy of the energy levels.
For example E(010)=E(001)=E(111) and then m_1 can take on 9 different values , m_2 and m_3 5 different values. So the degeneracy of this level is 3*9*5*5 ? Is it correct so far?
But then the j_i in turn are addtions of angular momentums.
Does this add even more to the degeneracy?
I would count the degeneracy of each estate as the product of 2j+1 for each sub j. So I think it is 3+3+27 for your example. You shouldn't just count the m's because they are correlated to give the j estates.
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
The value of H equals ## 10^{3}## in natural units, According to : https://en.wikipedia.org/wiki/Natural_units, ## t \sim 10^{-21} sec = 10^{21} Hz ##, and since ## \text{GeV} \sim 10^{24} \text{Hz } ##, ## GeV \sim 10^{24} \times 10^{-21} = 10^3 ## in natural units. So is this conversion correct? Also in the above formula, can I convert H to that natural units , since it’s a constant, while keeping k in Hz ?
