I need the proof of squeeze lemma on sequences
  • Thread starter Thread starter singedang2
    Proof Sequences
singedang2
urgent! i need the proof of squeeze lemma on sequences
if y_n \leq x_n \leq z_n and y_n \rightarrow p and z_n \rightarrow p
then x_n \rightarrow p
Note. I'm not looking for the proof of the regular squeeze theorem. this is supposed to be a proof adapting the proof of squeeze theorem onto the sequences.
What have you tried? You'll need to use the epsilon delta definition of the limit.
how am i suppose to apply this into the sequences?
Do you know the definition of the limit of a sequence? It's very similar in form to the epsilon delta definition used for functions.
If a_n\le b_n\le c_n and \lim a_n= \lim c_n= L then lim b_n= L.
Since lim a_n= L, then, given any \epsilon for some N1, if n> N1, |a_n- L|< \epsilon. Since lim c_n= L, given any \epsilon for some N2, if n> N2, |c_n- L|< \epsilon. If n> larger of (N1, N2) what can you say about both a_n and c_n. What does that tell you about c_n?
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
