How do I determine the height from which the stone is dropped?
morson
A balloon is rising vertically at a constant speed of 21 m/s. A stone is dropped from the balloon. The stone strikes the ground 10 seconds later. Assuming that air resistance is negligible and that acceleration on Earth due to gravity is 9.8 m/s2, from what height is the stone dropped?
v = u + at
dv/dt = a
dx/dt = v
This is screwing with my head. It's an obvious displacement problem, but where would you set the origin, to which the displacement is relative?
Here's my attempt:
The acceleration of the stone at any time is 9.8, and because this is constant
acceleration, v = u + at where a = 9.8 and u = 0 (because if you haven't dropped the stone yet, it must have a velocity of 0) .:. v = 9.8t
Integrating that you get x = 9.8(t^2/2) + c .:. x = 4.9t^2 + c
Here's where I run into trouble. WHERE IS THE ORIGIN?? Is it at the ground? At the balloon? At the height from which the stone is dropped? How do I define the displacement?
I tried x = 0 at the ground .:. x = 0 when t = 10 .:. 0 = 4.9(100) + c
.:. c = 490
so x = 4.9t^2 + 490
So the displacement at any time is equal to 4.9t^2 + 490.
We know that the stone is dropped after 0 seconds, so the height from which the stone is dropped would be a height of 490 metres, according to what I came up with.
If I'm wrong, could you please point out where I went wrong? In my approach I completely ignored the fact that the balloon rises at 21m/s. Is that part relevant?
Taking the orgin to be at a height of zero is perfectly OK. Ignoring the initial speed of the stone is not OK--it's not zero! (What's the initial speed of the stone?)
Choose a coordinate system and sign convention, such as "up is positive; down is negative". Note that the acceleration would be -9.8 m/s^2.
Thanks a lot. I'll revise what I did, then:
The initial speed of the stone is 21m/s, if I'm re-evaluating correctly. The acceleration is -9.8m/s^2.
The velocity is -9.8t + c ==> at t = 0, v = 21 ==> 21 = c so:
v = -9.8t + 21
Integrate to get X (displacement) = -9.8(t^2/2) + 21t + c
= -4.9t^2 + 21t + c
x = 0 when t = 10 ==> 0 = -490 + 210 + c ==> c = 280
x = -4.9t^2 + 21t + 280
At x = h, t = 0: h = 280
280 metres?
If it's correct, thanks a lot. If it's not, thanks anyway.
Looks good.
Okay, awesome.
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
