How Do You Simplify Complex Fractions with Different Denominators?
  • Thread starter Thread starter AznBoi
    Fraction
To simplify the complex fractions \(\frac{5}{a} + \frac{4}{2a-6} + \frac{-4a}{a^{2}-9}\), the common denominator identified is \(a(a+3)(a-3)\). The user initially struggled with combining the fractions and correctly identifying the common denominator. After some discussion, they clarified that \(2a-6\) can be factored to \(2(a-3)\), and \(a^2-9\) factors to \((a+3)(a-3)\). The conversation highlights the importance of recognizing common factors in the denominators to simplify the expression effectively. Overall, understanding the common denominator is key to combining and simplifying complex fractions.
AznBoi
Here is the fraction that I don't know how to combine and simplify, please help me out! Thanks! =]
\frac{5}{a} + \frac{4}{2a-6} + \frac {-4a}{a^{2}-9}
I found the common denominator I think: (x+3)(x-3) .. but how do you make {a} in that form?
Mathematics news on Phys.org
If I write it as \frac{5}{a}+\frac{2}{(a-3)}-\frac{4a}{(a+3)(a-3)} does it help?
Ok, I didn't see the bit you'd edited. The common denominator will be a(a+3)(a-3).
oh ok, I knew there wasn't a way to make {a} into {(a+3)(a-3)}. Thanks for your help! =]
You're very welcome!
Suppose ,instead of the usual x,y coordinate system with an I basis vector along the x -axis and a corresponding j basis vector along the y-axis we instead have a different pair of basis vectors ,call them e and f along their respective axes. I have seen that this is an important subject in maths My question is what physical applications does such a model apply to? I am asking here because I have devoted quite a lot of time in the past to understanding convectors and the dual...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
