Understanding the Trace Theorem in Calculating S-Matrix | QFT Explained
In summary: It's really helpful in understanding the use of traces in calculating the S-Matrix. In summary, the trace theorem is a useful tool in simplifying the calculations of the S-Matrix in QFT, and it can be found in most QFT books such as Griffiths chapter 7.7. The trace theorem involves manipulating the expression until the spinor terms are back-to-back, and then replacing it with the completeness matrix, which is a 4x4 matrix. The inner product, which is the sum of diagonal elements, can then be calculated using the trace of the matrix, making the calculations easier without needing to consider the specific spinor and matrix representations.
beta3
41
Hi guys,
Everyone knows that one can calculate the S-Matrix with various tricks. One of them is to use traces to simplify the matrices.
Can someone tell me or point me to a place where I can find an explanation why I can do this?
I think I vaguely remember that I have seen once an equation showing why traces can be used, but I can't recall that source (book? lecture notes? websites?)
Thanks
beta3 said:
Hi guys,Everyone knows that one can calculate the S-Matrix with various tricks. One of them is to use traces to simplify the matrices.
Thanks
You can find the trace theorem explained in most QFT books, for instance
in Griffiths chapter 7.7.
Now how does the Trace come in? First you manipulate the expression
until [itex]u[/itex] and [itex]{\bar u}[/itex] get back-to-back. This is an inner product:
[tex]u{\bar u}[/tex]
Then you replace it with the completeness matrix:
[tex]
\sum_{k\ =1,2} u^{(s)}{\bar u}^{(s)}\ =\ (\gamma^\mu p_\mu + mc)
[/tex]
This is a 4x4 matrix while you need the inner product: [itex]u_0{\bar u_0}+u_1{\bar u_1}+u_2{\bar u_2}+u_3{\bar u_3}[/itex]
Now, the inner product is the sum of the diagonal elements, and thus: The trace.[tex]
u{\bar u}\ =\ \mbox{Tr}(\ \gamma^\mu p_\mu + mc\ )
[/tex]Regards, Hans
It's important to remember just how many different labels and indices various entities in QFT actually having, a great deal of them are supressed and it's easy to forget or get confused between them.
In a slight elaboration of Hans' explanation, remember that spinors have a spinor index. [tex]\mathbf{u}[/tex] is a spinor with all terms supressed on it. It's a function of momentum, [tex]\mathbf{u}(p)[/tex], it's got spin (which for usual fermions are s = +-1/2) so [tex]\mathbf{u}^{s}(p)[/tex] and then there's the spinor index, which you can think of as the entry in the vector expression for the spinor, [tex]\mathbf{u}_{\alpha}^{s}(p)[/tex].
An inner product of spinors is [tex]\bar{\mathbf{u}}\mathbf{u}[/tex] (Hans has that the wrong way around), which when you put in all the various indices you have [tex]\bar{\mathbf{u}}_{\alpha}^{r}(p)\mathbf{u}_{\beta}^{s}(q)[/tex].
You how have an expression which is the inner product of two spinors of different spin (s,r labels), spinor polarisations ([tex]\alpha[/tex], [tex]\beta[/tex]) and momentum (p,q).
You'll get an equalisation of momentum, so p=q always.
Summing over spins and averaging means you can make use of the completeness relation Hans mentions, getting rid of spin complications and giving you
[tex]\sum_{s= \pm \frac{1}{2}} \bar{\mathbf{u}}_{\alpha}^{s}(p)\mathbf{u}_{\beta}^{s}(p) = p_{\mu}(\gamma^{\mu})_{\alpha \beta} + m \mathbb{I}_{\alpha \beta}[/tex]
From this formate you are able to compute specific reactions which have to take into account polarisation. This would involving saying what polarisation your incoming and outgoing particles are (ie giving values from 0 to 3 to alpha and beta in a specific choice of basis for your spinors and gamma matrices) and then working with the relevant entries within the matrix equation I just gave.
This is annoying for two reasons. Firstly, many experiments don't care about polarisation so unless it's desperately needed, it's more work than required. If you're only just learning QFT, it's certainly more work than required. Secondly, you have to pick a representation for your gamma matrices and the spinor basis, that meaning you have to give a specific form of your gamma matrices.
If instead you're only interested in averages and your expriments are blind to polarisation you just sum over them all so [tex]\alpha = \beta[/tex], but for any matrix [tex]M_{\alpha \beta}[/tex] the quantity [tex]M_{\alpha \alpha}[/tex] is the trace. This has the useful property that you don't need to pick a specific form for your spinors and your matrices, you get all the information you need from the gamma's anticommutation relation [tex]\{ \gamma^{\mu} , \gamma^{\nu} \} = g^{\mu \nu}[/tex]. Taking the trace of that immediately gives [tex]\textrm{Tr}(\gamma^{\mu} \gamma^{\nu}) = 4g^{\mu\nu}[/tex] and others follow from that and the anticommuting [tex]\gamma^{5}[/tex] matrix.
Just a small remark:
There is the inner product which gives the Lorentz scalar 2m:
[tex]\bar{\mathbf{u}}\mathbf{u} = 2m[/tex]
and then there is the inner product the other way round:
[tex]\mathbf{u}\bar{\mathbf{u}}[/tex]
Which, being less sloppy, I should write as the sum of two inner products:
[tex]\mathbf{u^\uparrow}\bar{\mathbf{u}}^\uparrow +
\mathbf{u^\downarrow}\bar{\mathbf{u}}^\downarrow\ =
\mbox{Tr}(\ \gamma^\mu p_\mu + mc\ )[/tex]
which gives us the Trace.Regards, Hans
^ Too true, my mistake, should have remembered that. Thinking too much about inner products giving scalars and not anything else. Sorry about that.
Wow, thanks for the neat explanation, AlphaNumeric and Hans
1. What is the Trace Theorem in QFT?
The Trace Theorem in Quantum Field Theory (QFT) states that the trace of an operator acting on a Hilbert space is equal to the sum of its eigenvalues. This theorem is used to simplify calculations in QFT and is a fundamental tool in theoretical physics.
2. How is the Trace Theorem used in QFT calculations?
The Trace Theorem is used to simplify calculations in QFT by reducing complicated integrals to summations of eigenvalues. This makes it easier to solve complex equations and models in theoretical physics, allowing for more accurate predictions and insights.
3. What is the significance of the Trace Theorem in physics?
The Trace Theorem is significant in physics because it allows for simpler and more efficient calculations in QFT. This makes it an essential tool for understanding and making predictions about the behavior of quantum systems, such as particles and fields.
4. Can the Trace Theorem be applied to non-quantum systems?
While the Trace Theorem was originally developed for use in quantum systems, it has also been applied in other fields such as statistical mechanics and number theory. However, its most common and important application is in QFT and its use in other fields may have limitations.
5. Is the Trace Theorem a proven theorem?
Yes, the Trace Theorem is a proven and well-established theorem in mathematics and theoretical physics. It has been extensively studied and tested, and its applications have been verified through various experiments and observations. It is an important and reliable tool in the study of quantum systems.
  • Quantum Physics
  • Quantum Physics
  • Quantum Interpretations and Foundations
  • Linear and Abstract Algebra
