Two vectors have magnitudes of 10 and 15
To solve the problem involving two vectors with magnitudes of 10 and 15 at a 65-degree angle, one should visualize the vectors and consider the right triangle formed. The component of the longer vector perpendicular to the shorter vector can be determined using trigonometric functions, specifically the sine function. By applying the sine of the angle between the vectors, the calculation yields the desired component length. The discussion emphasizes the importance of drawing the scenario for clarity and utilizing trigonometry to find the solution. This approach will lead to identifying the correct answer from the provided options.
nath_quam
Hey I'm just having trouble with this question
Two vectors have magnitudes of 10 and 15. The angle between them when they are drawn with their tails at the same point is 65 deg. The component of the longer vector along the line perpendicular to the shorter vector, in the plane of the vectors, is:
a)0
b)4.2
c)9.1
d)13.6
e)6.3
Thanks Nath
Show your attempt at a solution if this is a homework problem.
In fact, I am moving this to the homework forum.
Draw a picture of the situation. Do you see a right triangle? What trig function will help you find the length you want?
I tried to combine those 2 formulas but it didn't work. I tried using another case where there are 2 red balls and 2 blue balls only so when combining the formula I got ##\frac{(4-1)!}{2!2!}=\frac{3}{2}## which does not make sense. Is there any formula to calculate cyclic permutation of identical objects or I have to do it by listing all the possibilities? Thanks
Essentially I just have this problem that I'm stuck on, on a sheet about complex numbers: Show that, for ##|r|<1,## $$1+r\cos(x)+r^2\cos(2x)+r^3\cos(3x)...=\frac{1-r\cos(x)}{1-2r\cos(x)+r^2}$$ My first thought was to express it as a geometric series, where the real part of the sum of the series would be the series you see above: $$1+re^{ix}+r^2e^{2ix}+r^3e^{3ix}...$$ The sum of this series is just: $$\frac{(re^{ix})^n-1}{re^{ix} - 1}$$ I'm having some trouble trying to figure out what to...
