Chemistry How Do You Calculate Kp for the Formation of Ammonia from Nitrogen and Hydrogen?
To calculate Kp for the formation of ammonia from nitrogen and hydrogen, the standard Gibbs free energy for the reaction is -33.0 kJ at 298 K. The equation Keq = e^(-Delta G/RT) is used to find Kc, with R being 0.008314 kJ/K. The conversion from Kc to Kp utilizes the formula Kp = Kc(RT)^(delta Ng), where delta Ng is the change in moles of gas. The correct calculation yields Kp = 5.97 x 10^5, emphasizing the importance of using the correct value for R in joules. Accurate calculations are crucial for determining equilibrium constants in chemical reactions.
CausativeAgent
The standard Gibb's free energy for the reaction N2+3H2<--->2NH3 is -33.0 KJ at 298 K. Everything is a gas. Calculate Kp for this reaction.
I have in my notes that Keq=e^(-Delta G/RT) where R is the constant 0.008314 KJ/K. I also have a formula that converts between Kp and Keq: Kp= Kc(.0821Xtemperature)^(Moles of gasseous products-moles of gasseous reactants).
My attempt at a solution was to use the first formula (which I think gives Kc) and then convert it into Kp using the second formula.
My answer ended up differing from the one given in my homework though. Here is my work:
Keq= e^(33.0/(0.008314x298)= 6.09x10^5
Kp= (6.09x10^5)(0.0821x298)^(-2) = not the correct answer
The answer is: Kp=5.97x10^5
I think here, you have to use R=8.314 joules/mol . Keq can be calculated in the same way as you showed.
That is Kc. Kp=Kc(RT)^(delta Ng)
I don't get how to argue it. i can prove: evolution is the ability to adapt, whether it's progression or regression from some point of view, so if evolution is not constant then animal generations couldn`t stay alive for a big amount of time because when climate is changing this generations die. but they dont. so evolution is constant. but its not an argument, right? how to fing arguments when i only prove it.. analytically, i guess it called that (this is indirectly related to biology, im...
