Solving Electric Configuration Energy and Capacitance of Infinite Cylinders
  • Thread starter Thread starter Adamecius
Adamecius
Hi I am kinda new here, and my english its not the best so ill try to explain my problem in short words.
There is 2 problems which i already solve, but my question is more terorical that practical, these are the two problems:
a) Calculate the electric configuration energy per length of an infinite cylinder of charge density ρ. It turns out that when i use the equation that gives the configuration energy in terms of the potencial energy the problem have a solution , but when i use the equation that give the configuration energy in terms of the electric field the solution its infinite, and i cannot understand why.
b)The second problem is that, when i calculate the capacitance of 2 infinite cylinders that are very very far from each other, of charge and Radius Q1,R1 and Q2,R2 and both with length "l" using capacitance coefficients it turn out that the problem have a coherent solution, which is a capacitance that only depends of the geometry of the system. Hoever when i calculate the capacitance by definition the problem have a solution that depends of the charge which its imposible.
I will be really thanksfull if yopu could help with this, and i apreciate all the help:)
a)
Electric configuration energy in terms of electric field and potencial:
Uconf= (εo/2)∫(E^2)*dv Over the whole space
Uconf= ∫ρφ*dv over the volume of the object
b)Capacitance:
C= Qtrans/(φ2-φ1) Capacitance by definition
C= C11*C22-(C12^2)/(C11+C22+2C11C22) Capacitance using capacitance coheficients
The solution i give to both probles is that i believe that when we are making the aproximation of saying that the cylinders are infinite, for those equation where I am getting an infinite or not coherent solution that aproximation can't be done, probly becuase there are not such thing as infinite cylinders, and that kind of system its not consistent with the Unicity Theorem, and becuase of that we could have multyples solution to the same problem
Thx again and i apreciate your help see you all and i hope to help someon next time
This is right. Since you said that you're having problem with the integration, could you post your work? It'll be easier to help that way
Can you post your actual attempt at the solution?
Thread 'Help with Time-Independent Perturbation Theory "Good" States Proof'
(Disclaimer: this is not a HW question. I am self-studying, and this felt like the type of question I've seen in this forum. If there is somewhere better for me to share this doubt, please let me know and I'll transfer it right away.) I am currently reviewing Chapter 7 of Introduction to QM by Griffiths. I have been stuck for an hour or so trying to understand the last paragraph of this proof (pls check the attached file). It claims that we can express Ψ_{γ}(0) as a linear combination of...
