How do you treat cables in pulley and block arrangements?
  • Context: High School
  • Thread starter Thread starter leonel
    Blocks Pulleys
4 replies · 5K views
leonel
Can any of you help me in how to treat the cables in the arrangement pulleys and blocks attached ?.
thanks, Leonel
Is cable E fixed to the ground on one end, by that little parallelogram block?
Assuming that the cable is of fixed length and fastened at its end, then the length of the cable, E, is the distance from that fixed point to block B and so its length is increasing at 18 in/sec just like the blocks motion. Also, it is clear that, since the two pulleys can be taken to be right up against blocks A and B, C and D are of equal length at all times and so have the same rate of change.
Specifically, C+ D+ E= fixed length so dC/dt+ dD/dt+ dE/dt= 0. dC/dt= dD/dt and
dE/dt= 18: 2dC/dt= -18 or dC/dt= dD/dt= -9 in/sec.
Since the distance between blocks A and B are decreasing in length by 9 in/sec, A's speed relative to B is 9 in/ sec: yes, A's speed relative to the stationary base is 27 in/second.
HalsofIvy, thanks a lot for your response ! My thoughts have been the same of yours..
But, the problem is that the book responses are: cable D Velocity is assumed to be + 36 in/s while the Vcd is - 18 in/s. therefore, that makes Vc = + 18 in/s. What results in a complete difference...Maybe some typing problems (2 mistakes ??!) in the book "Vector Mechanics for engineers" Beer and Johnston" fifth ed. Ex.11.42.
