How Do You Calculate Tension and Compression in a Hanging Restaurant Sign?
To calculate the tension and compression in a hanging restaurant sign, one must consider the forces acting on the system, including the weight of the sign and the angles involved. The sign, weighing 25 kg, is suspended from a horizontal pole and connected to a cable, creating a scenario where both tension in the cable and compression in the pole need to be determined. Utilizing the sine law may be a starting point, but understanding moments (torques) is crucial for solving the problem accurately. A diagram of the setup can aid in visualizing the forces at play. Proper analysis of these forces will lead to the correct calculations of tension and compression.
webspherev6
a 25 kg restaurant sign hangs from a 1.25m horizontal pole with one end fastened at right angle to the brick wall of a restaurant and the other end fastened to a 2.5m cable . determine the force of compression actng on the pole and the tension in the cable.
im totally clueless this is a past test question. i was thinking u could possible use the sin law
t1=t2sin(angle2)/sin(angle1) ?? this is where t is the tension. i would like help understanding how to calculate them.
Oh i drew the diagram so i know how it loks like
Try looking at moments (torques).
I tried to combine those 2 formulas but it didn't work. I tried using another case where there are 2 red balls and 2 blue balls only so when combining the formula I got ##\frac{(4-1)!}{2!2!}=\frac{3}{2}## which does not make sense. Is there any formula to calculate cyclic permutation of identical objects or I have to do it by listing all the possibilities? Thanks
