Circular Motion: Acceleration Direction
In circular motion, an object moving uniformly has its acceleration directed toward the center of the circle, confirming the initial understanding. When an object is accelerating in circular motion, it possesses both a radial component, directed inward, and a tangential component, which indicates a change in speed. To determine the total acceleration direction, one must consider both components together. This dual-component approach is essential for accurately analyzing circular motion dynamics. Understanding these concepts is crucial for studying physics related to circular motion.
mwahx3
How would you know the direction of the acceleration of an object
a) moving uniformly in a circular motion
b) accelerating in a circular motion.
I'm pretty sure the answer to a is toward the center of the circle but I'm not so sure about b.
thanks.
Just by virtue of moving in a circle, the object must have a radial component of acceleration--so your answer for a is correct. If the object is accelerating in a circle, not just moving at constant speed in a circle, then it will also have a tangential component of acceleration. To find the direction of the total acceleration, you need both components.
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
