Why Does Ryder Use a 2π Factor in Equation 4.4 of QFT?
  • Thread starter Thread starter Jimmy Snyder
    Qft
Jimmy Snyder
The first expression in equation (4.4) is:
\frac{d^4k}{(2\pi)^4}2\pi\delta(k^2 - m^2)\theta(k_0)
Ryder is most ungenerous on this page. Some concepts, important to understanding the entire chapter are left unexplained. For instance, the reasoning that leads from the assumption that \phi is Hermitian, to the fact that
a(k)^{\dagger} = a(-k)
is not displayed or even mentioned. Also, unless I missed it, this is the first use of the Heaviside function in the book, yet it is not defined. Its use in this expression relates to the text where it says "with k_0 > 0". The use of the delta function relates to the text where it says "we have the 'mass-shell' condition". However I do not know where the factor of 2\pi comes from.
I assume that since there is one factor of 2\pi in the denominator for each degree of freedom, and the mass-shell condition removes one of those degrees of freedom, the factor is justified. Is there a more direct way of seeing why the factor is there?
That 1/\left(2\pi\right)^{4} comes out the convention he used to define the Fourier transform of the classical field \varphi.
I have no idea where that 2\pi in the numerator comes from. In my notes (4.3) appears after a redefinition of the classical complex amplitudes which is simply a 1/2\pi rescaling, so instead of f(p) and 1/\left(2\pi\right)^{4} i have a(p) and 1/\left(2\pi\right)^{3}. And this has nothing to do with any factors of 2\pi coming from the mass-shell condition.
It's annoying to see the face that Ryder doesn't use integrals in his derivation of (4.4). Mathematically speaking his entire calculation is garbage.
I hope to hear from someone who has.
Actually, except for the factor of 2 pi, I understand everything else in his derivation, so I don't think it's garbage. He does mention at the top of page 128 that there is an implied integration in equation (4.4).
In my opinion, he should have started with the plain vanilla Fourier expansion:
\phi(x) = \frac{1}{(2\pi)^4}\int d^4k a(k)e^{-ikx}
as it would have made the rest of the page easier to follow. It would allow him to emphasize the difference between eqn. (4.4) and (4.33) on page 135 where \phi is not assumed to be hermitian.
Hello everyone, I’m considering a point charge q that oscillates harmonically about the origin along the z-axis, e.g. $$z_{q}(t)= A\sin(wt)$$ In a strongly simplified / quasi-instantaneous approximation I ignore retardation and take the electric field at the position ##r=(x,y,z)## simply to be the “Coulomb field at the charge’s instantaneous position”: $$E(r,t)=\frac{q}{4\pi\varepsilon_{0}}\frac{r-r_{q}(t)}{||r-r_{q}(t)||^{3}}$$ with $$r_{q}(t)=(0,0,z_{q}(t))$$ (I’m aware this isn’t...
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
