Biology/Chemistry: pH Level and Ionizable Groups
  • Thread starter Thread starter Soaring Crane
    Groups Ph
The discussion revolves around the analysis of geranyl pyrophosphate, a molecule with three ionizable groups, at pH levels 1 and 7. At pH 1, the user questions whether all ionizable groups will be protonated, suggesting a structure that reflects this. At pH 7, the user seeks clarification on whether the groups will be unprotonated, presenting a revised structure. There is also uncertainty about treating the molecule as a triprotic acid, prompting a request for guidance on how to approach this concept. The conversation highlights the complexities of ionization states in different pH environments.
Soaring Crane
Select any molecule [from the assigned chapter] that has more than 2 ionizable groups. Write its structures, showing every atom, at pH levels 1 and 7.
See below.
http://en.wikipedia.org/wiki/Geranyl_pyrophosphate
The molecule that I chose is geranyl pyrophosphate:
____________________________________O_____O
____________________________________||____||
CH3C(CH3)=CHCH2CH2C(CH3)=CHCH2--O—P--O--P--O-
____________________________________|_____|
____________________________________O-____O-
This one does have 3 ionizable groups, right?
At pH 1, the molecule is under acidic conditions, so will all the ionizable groups be protonated?
CH3C(CH3)=CHCH2CH2C(CH3)=CHCH2--O--P--O--P--OH
____________________________________OH____OH
At pH = 7, the presence of water can be presumed(?), so does this arise?
CH3C(CH3)=CHCH2CH2C(CH3)=CHCH2--O—P--OH
+ __O
____||
HO--P--O-
____|
____O-
Thanks.
Revision here.
At pH 1, will all the groups be protonated like so?
At pH 7, will all the groups be unprotonated like so?
Or must I treat this like a triprotic acid in which each group is protonated at various instances? (If so, how do I go about doing this?)
Thank you.
I don't get how to argue it. i can prove: evolution is the ability to adapt, whether it's progression or regression from some point of view, so if evolution is not constant then animal generations couldn`t stay alive for a big amount of time because when climate is changing this generations die. but they dont. so evolution is constant. but its not an argument, right? how to fing arguments when i only prove it.. analytically, i guess it called that (this is indirectly related to biology, im...
