Will the capacitance increase or decrease?
Introducing a conductor between the plates of a capacitor affects its capacitance and overall behavior. If the conductor is momentarily introduced, the capacitor will discharge through it, influenced by the charge state and the properties of both the capacitor and conductor. If the conductor is permanently placed between the plates, the capacitance across the configuration remains the same, provided it maintains good contact with the plates. However, the overall reactance becomes more inductive, altering the impedance, especially at lower frequencies, and preventing the capacitor from storing charge indefinitely. When considering a parallel plate capacitor, inserting a metal plate without contact alters the capacitance. Initially, capacitance is inversely proportional to the distance between plates. With the metal plate in place, the new capacitance is calculated based on the modified distance. If the plate touches both capacitor plates, it effectively becomes a conductor rather than a capacitor.
lamp post
if we introduce a conductor b/w the plates of a capacitor then what will happen? will the capcitance increase or decrease?
If you mean momentarily, then the capacitor will discharge through the conductor at a rate determined by the instantaneous charge state, capacitance of the capacitor and conductance of the conductor.
If you mean permanently, then what is "the capacitance?" The capacitance across the configuration? If so, then it will remain the same, assuming that the conductor makes good contact with the plates. The overall reactance will become more inductive (I think), and the overall impedance will certainly change (pronounced at lower frequencies). One consequence will be that the capacitor can no longer store charge indefinitely. I suppose if you had some definition of capacitance that was based on the reactance, then it would decrease (that is, if it becomes more inductive as I assume it would).
lamp post,
Are you thinking of a parallel plate capacitor, with inititially nothing between the plates, and then you slide another metal plate into the empty space without touching the original plates?
If so, then I think the capacitance will increase. Originally the capacitance is proportional to 1/d where d is the plate separation. With the metal plate stuck in between, it will be 1/(d-t) where t is the thickness of the plate.
Is this metal plate touching both plates of the capacitor? If the answer is yes, you now have a conductor not a capacitor.
If it is only touching one plate then you have simply moved that plate. you must recompute the capacitance using the new area and separation.
If it is not touching either plate then you have constructed a pair of series capacitors, each with capacitance that can be found by consideration, as above, with the separation and area. The total capacitance will be found using the formula for addition of series caps.
