AMGM(n): Solving Problem 8 Part B
  • Thread starter Thread starter ehrenfest
6 replies · 3K views
ehrenfest
http://math.stanford.edu/~vakil/putnam07/07putnam1.pdf
Can someone help me with problem 8 part b?
I plugged that into AMGM(n) and the LHS easily transforms into the LHS of AMGM(n-1) but I am not sure how the RHS transforms to the RHS of AMGM(n-1). Specifically, what happens to the exponent?
This is the famous Cauchy proof of Am-Gm. Post what you dd so far.
Again, I plugged in the hint to AMGM(n) and the LHS easily transforms into the LHS of AMGM(n-1).
So I have the LHS of AMGN(n-1) is greater than or equal to [tex](\frac{a_1...a_{n-1} (a_1+...+a{n-1})}{(n-1)})^{1/n}[/tex]
and I do not know where to go from there.
Work with
[tex]\left( \frac{\sum a_i}{n} \right)^n \geq \prod a_i[/tex]
instead.
Keep an eye on the possibility of canceling something convenient off both sides after you apply the hint.
After I apply the hint, it looks like this:
[tex]\left( \frac{\sum_{i=1}^{n-1} a_i}{n-1} \right)^n \geq 1/(n-1)\sum_{i=1}^{n-1} a_i \prod_{i=1}^{n-1} a_i[/tex]
which is the same as
[tex]\left( \frac{\sum_{i=1}^{n-1} a_i}{n-1} \right)^{n-1} \geq \prod_{i=1}^{n-1} a_i[/tex]
because everything is nonnegative.
On to part c).
And of course I got stuck on part c) as well. I tried doing something similar like letting a_i = a_i + a_{n+i} or a_i = a_i *a_{i+n} but that only works for one side at a time. I tried to do the case k=2 "by hand" but there is the (a_1 +a_2+a_3+a_4)^4 part that is prohibitive. And I tried other stuff that was just as bad. So I am out of ideas.
Here, let's assume k=2 holds and show k=4.
[tex](a_1 a_2 b_1 b_2)^{1/4} = \left( (a_1 a_2)^{1/2} (b_1 b_2)^{1/2} \right)^{1/2} \leq \frac{(a_1 a_2)^{1/2} + (b_1 b_2)^{1/2}}{2}[/tex]
Can you take it from here?
