What is the original speed of a bullet fired into a ballistic pendulum?
  • Thread starter Thread starter xcvxcvvc
    Type
xcvxcvvc
A bullet of mass 10.0 g is fired into a ballistic pendulum of mass 3.00 kg. The pendulum swings back and rises 12.0 cm. Find the original speed of the bullet.
p1 + p2 = p1' + p2'
We're learning momentum right now, and I think that's what I need.
I'm too confused to even write much down. I've only thought about it. If the string's length isn't given, how can I solve this? If a string was 50000 meters long and someone hit it, wouldn't it swing less than a string 10 meters long? It would travel a different distance along the circumference with differing string lengths, right?I wrote this down and can't go any further: .5 * .01 * v^2 = 9.8 * .12 * 3.01(wrong answer for v) The only way I could write anything down was using energy, but that's not what this chapter is about :(. I don't even mind if you don't solve it all the way; a step in the right direction would be appreciated.
I should have posted this in introductory physics. Sorry, I was in a rush.
I figured it out. SOLVED Thanks for the... forum space? lol
I'll explain how I did it just in case someone finds this post in search of the answer i sought.
(m1 + m2) * g * h = 1/2 * (m1 + m2) * v^2
the potential energy gained by the masses together(since they stuck) equals the kinetic energy of both masses RIGHT when the bullet struck.
Momentum in this system is conserved so p1 + p2 = p1' + p2'
m1 * v + m2 * 0 = (m1 + m2) * (the v we found up there)
solve for v
Hello everyone, I’m considering a point charge q that oscillates harmonically about the origin along the z-axis, e.g. $$z_{q}(t)= A\sin(wt)$$ In a strongly simplified / quasi-instantaneous approximation I ignore retardation and take the electric field at the position ##r=(x,y,z)## simply to be the “Coulomb field at the charge’s instantaneous position”: $$E(r,t)=\frac{q}{4\pi\varepsilon_{0}}\frac{r-r_{q}(t)}{||r-r_{q}(t)||^{3}}$$ with $$r_{q}(t)=(0,0,z_{q}(t))$$ (I’m aware this isn’t...
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
