Cofactor Expansion: Find Determinant of 4x3 Matrix
  • Thread starter Thread starter fk378
    Expansion
fk378
Find the determinant of
4...3...-5
5...2...-3
0..-1...2
I've tried to get the answer using each of the 3 rows and each time I get a different answer. For the first row I get 14, the second row I get -31, and the third row I get -1. However, I thought that the determinant would be the same value for whichever row (or column) you choose to expand.
4...3...-5
5...2...-3
0..-1...2
Yes, it certainly should be!
Expanding by the first column (since it has only 2 non-zero entries):
\left|\begin{array}{ccc}4 & 3 & -5 \\ 6 & 2 & -3 \\ 0 & -1 & 2 \end{array}\right|= 4\left|\begin{array}{cc}2 & -3 \\ -1 & 2\end{array}\left|- 5\right|\begin{array}{cc} 3 & -5 \\ -1 & 2\end{array}\right|
4(4- 3)- 5(6- 5)= 4(1)- 5(1)= -1
The determinant is -1. I notice that is what you got using the third row which also has only two non-zero entries. Perhaps it is that third entry that is confusing you.
But if you try to work out the determinant using the other rows that do not contain the 0 entry, it does not come out to -1! Why?
Ah, I just realized I wasn't multiplying one of the terms with the cofactor expansion! I feel silly...thanks for your help though!
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
