Need Help With Buffers: Test on Tuesday!
  • Thread starter Thread starter STAR3URY
    Buffers Urgent
Understanding buffers is crucial for your upcoming test. Buffers resist pH changes, and the concentration of H+ ions can be calculated using the dissociation constant (Ka) and the concentrations of the acid and its salt. For example, using ethanoic acid and sodium ethanoate, the formula for H+ concentration is Ka multiplied by the concentration of the acid divided by the concentration of the salt. To find the pH of the buffer, apply the formula pH = -log[H+]. Clarifying your knowns and unknowns will help in solving buffer-related problems effectively.
STAR3URY
Very Urgent: Need Help With Buffers!
I have a test coming up on Tuesday and I have no idea how to do buffers, I don't understand what Value of the Ka we are suppose to use from the chart. I get the equation a little bit: [H+]= Ka x moles HB/moles of B-
I am very lost please help!
What? Your problem description and question are poor. What are your knowns and what are you unknowns?
ok... i'll try to help you out a bit...
you should know that buffers resist drastic change in pH.
basically, the H+ ion concentration in a buffer solution is:
Ka * [acid] / [salt]
or for an alkaline buffer
Kb * [alkali] / [salt][acid] would mean the concentration of the acid in mol/dm3
if you use ethanoic acid and sodium ethanoate as the buffer, then H+ concentration is
dissociation constant of ethanoic acid * concentration of ethanoic acid / concentration of sodium ethanoate
the question will usually ask you about the pH of the buffer. to get the pH:
pH = -lg [H+]
I don't get how to argue it. i can prove: evolution is the ability to adapt, whether it's progression or regression from some point of view, so if evolution is not constant then animal generations couldn`t stay alive for a big amount of time because when climate is changing this generations die. but they dont. so evolution is constant. but its not an argument, right? how to fing arguments when i only prove it.. analytically, i guess it called that (this is indirectly related to biology, im...
