Finite element result in arbitrary point
To calculate finite element analysis results at arbitrary points, using shape functions is a viable approach, though determining the appropriate element for a point in a complex 3D model can be challenging. An alternative method involves using a weighted average based on integration points or nodes, raising questions about its accuracy. Interpolation methods are generally considered acceptable for engineering purposes, provided the original finite element results are reliable. Smooth stress distributions make interpolation a reasonable choice. Overall, both methods have their merits and can be effective depending on the context.
johan_ekh
Hi all,
I have to write a small program that reads the results from a finite
element analysis and calculates some results in arbitrary points.
The results could be either nodal or element based.
What would be the best approach to do this?
I've thought about using the shape functions to calculate the
results but in a general 3D model with curved element edges I
don't even know how to determine what element the arbitrary
point belongs to.
Another idea would be to forget about the shape functions and
use a weighted average based on either the integration points
or the nodes, but would that be accurate?
Any suggestions are welcome!
Johan
hihi johan, IMO the interpolation method is a good try, and the result is good enough for engineering purpose(as long as the FE result set is good enough). Most stresses are smooth and it is reasonable to interpolate
I need some assistance with calculating hp requirements for moving a load. - The 4000lb load is resting on ball bearing rails so friction is effectively zero and will be covered by my added power contingencies. Load: 4000lbs Distance to travel: 10 meters. Time to Travel: 7.5 seconds Need to accelerate the load from a stop to a nominal speed then decelerate coming to a stop. My power delivery method will be a gearmotor driving a gear rack. - I suspect the pinion gear to be about 3-4in in...
Thread 'Turbocharging carbureted petrol 2 stroke engines'
Hi everyone, online I ve seen some images about 2 stroke carbureted turbo (motorcycle derivation engine). Now.. In the past in this forum some members spoke about turbocharging 2 stroke but not in sufficient detail. The intake and the exhaust are open at the same time and there are no valves like a 4 stroke. But if you search online you can find carbureted 2stroke turbo sled or the Am6 turbo. The question is: Is really possible turbocharge a 2 stroke carburated(NOT EFI)petrol engine and...
How did you find PF?: Via Google search Hi, I have a vessel I 3D printed to investigate single bubble rise. The vessel has a 4 mm gap separated by acrylic panels. This is essentially my viewing chamber where I can record the bubble motion. The vessel is open to atmosphere. The bubble generation mechanism is composed of a syringe pump and glass capillary tube (Internal Diameter of 0.45 mm). I connect a 1/4” air line hose from the syringe to the capillary The bubble is formed at the tip...
