Sector angle and segment area just given only 2 variables ?
Calculating the sector angle and segment area of a circle requires the radius and the chord length. The sagitta length can be determined using the formula S = r - √(r² - (1/2)l²), where r is the radius and l is the chord length. The sine function is applied to find the half sector angle, using the relationship sin(1/2 sector angle) = (1/2)l/r. This discussion focuses on deriving these values from the given variables. Understanding these calculations can aid in solving problems related to circular segments.
CGUE
Is there a way to calculate the sector angle and segment area of a circle just given only the radius and the length of the circle ?
So far I can only calculate the sagitta length using the radius and length of the chord i.e.
S = r - \sqrt{r^2 - \frac{1}{2}l^2}
Where r is the radius of the circle and l is the length of the chord.
Mathematics news on Phys.org
Hi CGUE ! :smile:
sin = opp/hyp …
sin 1/2 sector angle = 1/2 l/r :smile:
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Suppose ,instead of the usual x,y coordinate system with an I basis vector along the x -axis and a corresponding j basis vector along the y-axis we instead have a different pair of basis vectors ,call them e and f along their respective axes. I have seen that this is an important subject in maths My question is what physical applications does such a model apply to? I am asking here because I have devoted quite a lot of time in the past to understanding convectors and the dual...
