Airplane Wing Lift: Bernoulli & Newton's Laws
  • Thread starter Thread starter 50936
    Airplanes Lift
The discussion centers on the lift generated by airplane wings, focusing on the contributions of the Bernoulli effect and Newton's laws. The author seeks to calculate the actual lift values using specific wing profile data but is currently facing challenges. Recommendations include utilizing resources from NASA, which provides detailed measurements and software like FoilSim II for theoretical lift calculations. The conversation emphasizes the importance of accurate data for understanding lift mechanics. Overall, the thread highlights the intersection of theoretical principles and practical application in aerodynamics research.
50936
Lift ! (airplanes)
Hello,
I am writing a research paper about the lift generated by the wings of an airplane.
It is about the extent to which the Bernoulli effect and Newton's laws each contribute to creating lift.
I planned on calculating the actual value of the lift generated by each, using data on the wing profiles of airplanes. But so far, I have only managed to get stuck.
Any ideas on how I should go about doing this?
PS Does anybody know where I can get detailed data/measurements of airplane wing profiles?
A good starting point is NASA: http://www.grc.nasa.gov/WWW/K-12/airplane/bga.html"
They also offer several http://www.grc.nasa.gov/WWW/K-12/freesoftware_page.htm" , such as:
"FoilSim II computes the theoretical lift of a variety of airfoil shapes. The user can control the shape, size, and inclination of the airfoil and the atmospheric conditions in which the airfoil is flying."
How did you find PF?: Via Google search Hi, I have a vessel I 3D printed to investigate single bubble rise. The vessel has a 4 mm gap separated by acrylic panels. This is essentially my viewing chamber where I can record the bubble motion. The vessel is open to atmosphere. The bubble generation mechanism is composed of a syringe pump and glass capillary tube (Internal Diameter of 0.45 mm). I connect a 1/4” air line hose from the syringe to the capillary The bubble is formed at the tip...
Thread 'Physics of Stretch: What pressure does a band apply on a cylinder?'
Scenario 1 (figure 1) A continuous loop of elastic material is stretched around two metal bars. The top bar is attached to a load cell that reads force. The lower bar can be moved downwards to stretch the elastic material. The lower bar is moved downwards until the two bars are 1190mm apart, stretching the elastic material. The bars are 5mm thick, so the total internal loop length is 1200mm (1190mm + 5mm + 5mm). At this level of stretch, the load cell reads 45N tensile force. Key numbers...
I'd like to create a thread with links to 3-D Printer resources, including printers and software package suggestions. My motivations are selfish, as I have a 3-D printed project that I'm working on, and I'd like to buy a simple printer and use low cost software to make the first prototype. There are some previous threads about 3-D printing like this: https://www.physicsforums.com/threads/are-3d-printers-easy-to-use-yet.917489/ but none that address the overall topic (unless I've missed...
