Pulsing high current into capacitive load?
  • Thread starter Thread starter waht
    Current Load
The discussion centers on pulsing 80 Amps at 1 KHz into a capacitive load, where the high RC constant prevents the current from starting at zero amps. A temporary fix involved using a 0.75 ohm resistor in parallel to discharge the load, but this resulted in significant power waste. Suggestions included using a higher resistor and ensuring a faster decay rate, with recommendations for a variable square wave generator and MOSFETs. Ultimately, the issue was resolved by generating a second low-powered pulse that was 180 degrees out of phase to effectively discharge the capacitor. The solution improved the efficiency of the pulse generation process.
waht
I have to pulse 80 Amps @ 1 KHz into a capacitive load of a few uF. Unfortunately the RC constant is high enough that it prevents the next pulse to start from 0 amps. So in a sense the pulse generator delivers about 70 to 80 amps per cycle instead of 0 to 80 amps like it would in a non-capacitive load.
I fixed this temporarily by hooking up a 0.75 ohm high current resistor in parallel so it could discharge the load when the pulse is off. However I'm wasting a lot of power this way.
So I'm wondering if there is another solution?
You might try being more specific about the purpose of your setup and what it is intended to accomplish.
put a higher resistor instead of a such small one.
your decay rate should be faster than 1msec, let's say it is about 0.2msec, so RC = 0.2msec => R = 200ohms?
Have you tried using a variable square wave generator and a mosfet?
Thanks for replying, but the problem has been solved two months ago. We basically generated a second low powered 180 degree out of phase pulse to discharge the cap.
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
I am not an electrical engineering student, but a lowly apprentice electrician. I learn both on the job and also take classes for my apprenticeship. I recently wired my first transformer and I understand that the neutral and ground are bonded together in the transformer or in the service. What I don't understand is, if the neutral is a current carrying conductor, which is then bonded to the ground conductor, why does current only flow back to its source and not on the ground path...
