Phi (the golden ratio) in prime quadruplets
Phi, the golden ratio, appears at the center of prime quadruplets, along with its square root and cube root. The discussion highlights how the positions of prime numbers contribute to these values, with the center of the quadruplet assigned a value of 44.5. However, there is debate over whether this connection is significant, as the ratio derived (44.5/27.5) is a rational number, not the irrational phi. Critics argue that finding numbers close to phi is not surprising given the ability to manipulate formulas and spacing. The conversation emphasizes skepticism about the significance of these approximations in relation to phi.
Arcw
Phi exists at the center of prime quadruplets, along with its square root, and cube root!
http://www.code144.com/zphithrice.png
The 'pos' numbers come from the position of the prime numbers in the sequence itself, i.e. 193 is the 44th prime number, and 197 is the 45th prime number, thus, the center of the prime quadruplet (105) gets assigned a value at the center of these (44.5), and these numbers can make Phi!
Do you think it is strange that Phi is hiding here?
Mathematics news on Phys.org
I think it is strange that you think phi is "hiding" in there. What you show is the ratio of two half integers, 44.5/27.5= 1.6181818... which is NOT phi. That is a rational number while phi is irrational. Yes, it is "close" to phi (if you consider two decimal places "close") but it is easy to find numbers "close" to any given number if you look long enough.
Do you think it is a coincidence that the square root, and cube root (also to approximations) of Phi then directly follow, in that order, and all occur at the center of the quadruplets.
Get a probability guy over here, stat. :wink:
And by the way, it's three decimal places, not two -- and the cube root that follows is accurate to 5 decimal places.
You're not even using the same formula for all of them. Or the same spacing. Or the same column.
What are the odds of finding approximations of three given values when you can manipulate the formula, spacing, and column? Pretty damn good.
Suppose ,instead of the usual x,y coordinate system with an I basis vector along the x -axis and a corresponding j basis vector along the y-axis we instead have a different pair of basis vectors ,call them e and f along their respective axes. I have seen that this is an important subject in maths My question is what physical applications does such a model apply to? I am asking here because I have devoted quite a lot of time in the past to understanding convectors and the dual...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
