Conservation of energy for charging a capacitor
Charging a capacitor with a battery and then disconnecting it before connecting to another capacitor results in energy loss due to thermal radiation and light as charges transfer. The equations for potential energy in both scenarios indicate that the energy after connecting two capacitors is less than the initial energy stored in the single charged capacitor. The loss of energy can be quantified using the formula for energy lost, which incorporates current and resistance during the transfer. The discussion emphasizes that charging through a resistor is inefficient, leading to energy dissipation, while charging through an inductor avoids such losses. Understanding these dynamics is crucial for analyzing energy conservation in capacitor systems.
casanova2528
one capacitor is charged with a battery. then the capacitor is disconnected away from the battery. Then, the capacitor is hooked up to another capacitor. the result involves losing of energy to thermal radiation and light as the charges from one capacitor moves to the other capacitor.
another situation involves having two parallel capacitors hooked up to a battery to be charged. then, the battery is disconnected. This situation includes the summation of potential energies of both capacitors to figure out the total potential energy of the system.
this makes sense.
However, I can't seem to pin point at where in the equations involved in situation 1 do we see the loss of this energy as the charges flow to the other capacitor.
In other words, you cannot add up the potential energies of both capacitors and equate it to the potential energy of the 1 capacitor hooked up to the battery.
here's a bit of the math.
u = .5(q squared) / C1 = potential energy of the one capacitor hooked up to the battery.
u = .5 (c)(v squared) = potential energy of the two capacitors hooked up to each other without battery.
u = .5(C1 + c2)(Vsquared) = total energy of the connected capacitors.
V of the connected capacitors = C1V1/(C1 + C2) where V1 = electric potential of the battery.
u = .5(C1V1)squared/(C1 + C2)
this energy is less than u=.5(Qsquared)/C1 = .5(C1)(V1 squared)
WHERE IS THE LOSS OF ENERGY?? WHERE IN THIS EQUATION CAN WE DEDUCE THAT THERMAL ENERGY IS BEING LOST?
I is very clear, you mentioned the missed energy in that sentence.
Creative thinking is enjoyable, Then think about your surrounding things and other thought products. http://electrical-riddles.com
Hi casanova2528! :smile:
The equation you need is energy lost = power x time = ∫I(t)2 R dt for the current, I(t), which flows from one capacitor to the other, through wires of resistance R.
From the PF Library:
Inverse exponential rate of charging:
A capacitor does not charge or discharge instantly.
When a steady voltage V_1 is first applied, through a circuit of resistance R, to a capacitor across which there is already a voltage V_0, both the charging current I in the circuit and the voltage difference V_1\,-\,V change exponentially, with a parameter -1/CR:
I(t) = \frac{V_1\,-\,V_0}{R}\,e^{-\frac{1}{CR}\,t}
V_1\ -\ V(t) = (V_1\,-\,V_0)\,e^{-\frac{1}{CR}\,t}
So the current becomes effectively zero, and the voltage across the capacitor becomes effectively V_1, after a time proportional to CR.
Energy loss:
Energy lost (to heat in the resistor):
\int\,I^2(t)\,R\,dt\ =\ \frac{1}{2}\,C (V_1\,-\,V_0)^2[/itex]<br /> <br /> Efficiency (energy lost per total energy):<br /> <br /> \frac{V_1^2\,-\,V_0^2}{V_1^2\,-\,V_0^2\,+\,(V_1\,-\,V_0)^2}\ =\ \frac{1}{2}\,\left(1\,+\,\frac{V_0}{V_1}\right)<br /> <br /> Accordingly, charging a capacitor through a resistor is very inefficient unless the applied voltage stays close to the voltage across the capacitor.<br /> <br /> But there is no energy loss on charging a capacitor through an inductor, basically because the applied voltage then appears across the inductor instead of across the capacitor.
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
I am not an electrical engineering student, but a lowly apprentice electrician. I learn both on the job and also take classes for my apprenticeship. I recently wired my first transformer and I understand that the neutral and ground are bonded together in the transformer or in the service. What I don't understand is, if the neutral is a current carrying conductor, which is then bonded to the ground conductor, why does current only flow back to its source and not on the ground path...
