Kinematics, volcano eruption speed problem
A volcano launches a lava bomb with an initial speed of 28 m/s, and the discussion focuses on calculating its speed and direction after 2.0 and 3.0 seconds. The key knowns include initial velocity, acceleration due to gravity, and time, while the unknown is the instantaneous velocity at specified times. Participants clarify that acceleration due to gravity should be considered, even if not explicitly stated in the problem. The initial confusion stemmed from the lack of clear instructions regarding the inclusion of gravitational effects. Understanding these concepts is essential for solving the problem accurately.
rsfancy
A volcano launches a lava bomb straight upward with an initial speed of 28 m/s.
a)Taking upward to be the positive direction, find the speed of the lava bomb 2.0 seconds after it is launched.
b)Taking upward to be the positive direction, find the direction of motion of the lava bomb 2.0 seconds after it is launched.
Upward or Downward?
c)Taking upward to be the positive direction, find the speed of the lava bomb 3.0 seconds after it is launched.
d)Taking upward to be the positive direction, find the direction of motion of the lava bomb 2.0 seconds after it is launched.
Upward or Downward?
I know this stuff is pretty basic, but my prof. won't explain or give us examples of anything,so I'm really confused. Anything to point me in the right direction would be helpful. Thank you.
I'm going to specifically talk about part a, and then after you understand part a, the rest should be easy.
Ok, you have 3 knowns and you are searching for 1 unknown. Your knowns include: initial velocity, acceleration and time. Your unknown is the instantaneous velocity at a specified time. Now, what formula matches your knowns and unknown?
Wow, thank you very much. That definitely helped me see what was going on. I did get confused at first when you said that acceleration was known, and I did figure it would be gravity but the problem didnt explicitly state we should take into consideration, and I thought it would if we were meant to, as it did with the previous problems and that was my single problem with all of this...I can't even begin to explain how retarded I feel.
Thanks a lot for your help!
Thread 'Correct statement about a reservoir with outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
