Chemistry Solving pH 0: 2 Moles of H3O+ per 100 Moles of Water
  • Thread starter Thread starter Bridget
    Ions Moles
pH 0 indicates a highly acidic solution, corresponding to approximately 2 moles of H3O+ ions per 100 moles of water. This translates to a concentration of H+ ions that significantly impacts the solution's acidity. In a 1-liter solution, there are about 55.5 moles of water, which helps clarify the relationship between moles of H3O+ and water. Understanding this ratio is crucial for grasping the implications of such low pH levels. The discussion highlights the importance of recognizing the moles of water when calculating pH and H+ concentrations.
Bridget
Hi,
I came across this statement and an explanation to this is greatly appreciated as I can't figure this out.
"pH 0 means ~ 2 moles of H3O+ for each 100 moles water"
Thank you.
pH 0 - how many moles of H+ per liter of solution?
1 liter of solution - how many moles of water?
Oops!
Got it!
I don't get how to argue it. i can prove: evolution is the ability to adapt, whether it's progression or regression from some point of view, so if evolution is not constant then animal generations couldn`t stay alive for a big amount of time because when climate is changing this generations die. but they dont. so evolution is constant. but its not an argument, right? how to fing arguments when i only prove it.. analytically, i guess it called that (this is indirectly related to biology, im...
