Modelling Gravitational Motion
The discussion focuses on modeling the gravitational motion of two particles, where one particle is stationary and the other has an initial position and velocity. The user is successfully calculating the gravitational force vector but is uncertain about how to incorporate the momentum of the moving particle into the model. They reference Newton's laws of gravitation and motion to derive the necessary equations. A suggestion is made to simplify the model by initially assuming a constant gravitational force to validate the calculations. Overall, the conversation emphasizes the importance of correctly integrating momentum into the gravitational motion equations.
microguy
Modelling "Gravitational" Motion
Hi All,
I am new here and this is not a homework question... I'm turning 40 this year and my retention of physics is low to say the least. I am trying to rekindle some knowledge... Just for fun!
I am trying to use a spreadsheet to model the motion of a system of two particles under gravitational-type forces where one particle has a fixed position and the other is given an initial position and velocity vector. Both particles also have a known mass, e.g.,
P1(m1,x1,y1) [fixed position]
P2(m2,x2,y2,v2)
The way I'm approaching this, P2 should move predictably in a time-slice dt. P2 is influenced by its momentum as well as the "gravitational" attraction to P1.
I can figure the "gravitational" force vector with no problem.
The thing I am hung up on is how to figure the contribution of P2's momentum. I'm not even sure I'm using the correct term here. Once I know how to calculate this vector correctly, I think I can do the math.
Please let me know if anything is unclear.
Thanks!
Maybe something along these lines
F=Gm1m2/(distance between the masses)2 [Newton's law of gravitation]
F=m2(change in velocity)/(change in time) [Newton's 2nd law of motion]
Combining the two laws
Gm1m2(change in time)/(distance between the masses)2=m2(change in velocity)
You can cancel m2 out, and start with 1D motion to see if it makes sense. There's a minus sign somewhere you have to take care of, but I don't remember - just choose it so that gravity attracts, not repels the masses.
Edit: Actually, you can start out with a calculation in which gravity is constant (ie. not dependent on the distance between the masses), just to see if it makes sense. Of course, that result will only be correct over short distances, but it sometimes helps to start with a simple situation.
Thanks for that! This makes sense and you helped me notice something I was not doing quite right.
I have recently been really interested in the derivation of Hamiltons Principle. On my research I found that with the term ##m \cdot \frac{d}{dt} (\frac{dr}{dt} \cdot \delta r) = 0## (1) one may derivate ##\delta \int (T - V) dt = 0## (2). The derivation itself I understood quiet good, but what I don't understand is where the equation (1) came from, because in my research it was just given and not derived from anywhere. Does anybody know where (1) comes from or why from it the...
