Modulus for X Axis: Can You Stop Negative Values?
  • Thread starter Thread starter madmike159
    Axis Modulus
The discussion revolves around the concept of using modulus functions to prevent negative values on the x-axis in mathematical graphs. While y = |x| remains positive, the question arises about whether a modulus can be applied to x to avoid negative values, particularly in contexts like radioactive decay where negative time is conceptually challenging. Participants clarify that negative time can be defined relative to a chosen starting point, allowing for calculations that yield meaningful results even before that point. The conversation also touches on the need for an "opposite" of the modulus function, although no clear solution is presented. Overall, the dialogue emphasizes the flexibility of time in mathematical applications and the challenges of representing certain phenomena graphically.
madmike159
y = |x| can't go below the y-axis because a Modulus is always positive, but can you get a modulus that stops x going negitive? Could this be used for things like radioactive decay where the graph should go in -x but doesn't because you can't have - time?
Mathematics news on Phys.org
x, as a function of y, x= |y| does that. I am not clear why you say "you can't have negative time". There is no such thing as an "absolute" time. In any application of mathematics, to, say, physics, you are free to choose which moment you will call "t= 0". Negative values of t simply mean times before your chosen starting point.
For example, if I have a radioactive substance, with half-life \lambda, that, at time 0 (say, when I start the experiment) has mass m= A grams, then as time t, it will have mass m= A(1/2)^{\lambda t}. Taking t< 0 will give a mass greater than A, which is a perfectly reasonable answer: before time t= 0, it had greater mass than at time t= 0.
"Taking t< 0 will give a mass greater than A, which is a perfectly reasonable answer: before time t= 0, it had greater mass than at time t= 0."
Unless it was created at some time as a by-product of a nuclear reaction.
Really all I wanted to know is if there is an opposite of the modulus function.
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Suppose ,instead of the usual x,y coordinate system with an I basis vector along the x -axis and a corresponding j basis vector along the y-axis we instead have a different pair of basis vectors ,call them e and f along their respective axes. I have seen that this is an important subject in maths My question is what physical applications does such a model apply to? I am asking here because I have devoted quite a lot of time in the past to understanding convectors and the dual...
