Dual Power Sources: Supplementing Solar w/ Battery
The discussion focuses on integrating a battery with a solar cell to maintain a consistent power supply. The original poster seeks advice on how to manage power input levels, specifically how to switch to battery power when solar output drops. Suggestions include using microcontrollers for control and considering automotive electrical systems as a model, where the battery is the primary power source and the solar cell acts like an alternator. There is debate over using diodes versus transistors for efficiency, with power MOSFETs being recommended for lower switch losses. Overall, the conversation emphasizes the need for effective power management in hybrid solar and battery systems.
HybridLogic
Hey!
I'm trying to create something with some power cells, and I've run into the issue of inconsistent power supply.
I'd like to supplement power from a solar cell with a battery, but I'm not exactly sure how to keep the input to something at a set value. Basically, when the solar cell supply falls below a certain level, I'd like to supply the missing power with the battery.
Anyone have any ideas? I really don't know if any hardware exists for this already. The idea of using a microcontroller came up (and I can write assembly, so using one's not an issue).
Thanks for any input.
Good post, Mheslep, but I can't help thinking that there's an easier approach. The way an automotive electrical system works is that everything runs off of the battery, and the alternator keeps it charged. In this situation, the power cells can be subbed in for the alternator.
Easier than two diodes? OP didn't discuss charging the battery from the PV. If he/she wants that they need something different.
The problem with diodes is that they waste some power. Better maybe to use to transistors which are switched fully on by a control signal.
Any kind of semiconductor gate will have losses in its on state. Power MOSFETS have the lowest switch losses. I don't know if that's any better than a good Schottky diode (.1, .2V forward bias). In any case, an transistor/FET that's turned on is effectively just a diode.
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I am not an electrical engineering student, but a lowly apprentice electrician. I learn both on the job and also take classes for my apprenticeship. I recently wired my first transformer and I understand that the neutral and ground are bonded together in the transformer or in the service. What I don't understand is, if the neutral is a current carrying conductor, which is then bonded to the ground conductor, why does current only flow back to its source and not on the ground path...
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
