Why Does Electricity Need to Return to the Positive Terminal?
  • Thread starter Thread starter cam875
Electricity requires a return to the positive terminal because electrons are attracted to positive charges, creating a flow that generates current. A battery initiates this flow by establishing a potential difference between its terminals, with resistance in the circuit facilitating electron movement toward the positive terminal. Metals conduct electricity better due to their small bandgap, allowing electrons to easily transition into the conduction band, enhancing their mobility. The number of electron orbits in an atom influences conductivity, as outer electrons are more easily displaced. Understanding these principles involves concepts from Ohm's Law and circuit theory, which explain the behavior of electrical currents in various materials.
cam875
Ive read a few things about electricity since i haven't brushed up on it in a while, and I realize that a generator pushes the electrons and each one hits off the other one producing an electrical current but only when it returns to the positive terminal, why does it have to return to the positve terminal, i don't remember being explained this and I am just curious.
Also what are the most common forms of generators used in electrical circuits? and what is the generator for the human bodies electrical currents to take place?
electrons are attracted to net positive charges, that's why the electron flow is toward the positive terminal. electron flow is in the opposite direction of conventional current flow, but i think that is an artifact of network theory. some people, military i think, learned current flow in the same direction as electron flow.
in the body, cells pump ions such as sodium and potassium through their membranes, producing a net charge across the membrane(polarization). when say a nerve cell opens up these channels and depolarizes, it starts a chain reaction by depolarizing the cell adjacent to it. this traveling depolarization wave is probably the current you're thinking about. you can also observe muscle activity by measuring electric fields on the skin surface (myogram). for details, you could check a physiology textbook like Guyton's Physiology. i don't trust my memory that well, anyway.
can u explain to me how a very simple battery works because I don't understand how the battery starts the electron flow. I mean doesn't something have to instigate the battery to produce an electron flow?
also why are metals so much better at conducting electricity?
and is it better to use atoms that have more orbits of electrons since those electrons on the outside of the atom are easier to be bumped off and help continue the current?
To answer your question as precisely as possible, a battery is stored charge between two terminals; a positive and negative. Quite frankly, the resistance that closes the circuit produces the electron flow since the electrons want to flow towards the positive terminal and produce a current flowing into the positive terminal (passive sign convention). Its simply an application of Ohms law and understanding KVL and KCL along with other preliminary circuit models.
As for your question about why metals are better at conducting, you probably remember something called Bohr's Model which is a diagram of the nucleus with concentric energy levels with various designations of states in each. The topmost energy level known as the valence band has a bandgap with the conduction band which is the next highest energy level that an electron can 'escape' to via thermal excitation or photon absorption. In short, the bandgap Eg is very small and minimal excitation is required for electrons to jump into the conduction band of a crystal, perhaps an alloy of some sort, where free electrons mobility increases and now current can be produced. The larger the bandgap, the more insulator like the crystal behaves since ALOT of energy will be required to have electrons jump into the conduction band.
The closer you are to the nucleus, the strong force gets stronger and stronger. The more electron energy levels you have filled, the smaller the bandgap should be.
This is my understanding. Correct me if anything needs clarification.
so how do u tell what the bandgap is for a specific atom?
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
I am not an electrical engineering student, but a lowly apprentice electrician. I learn both on the job and also take classes for my apprenticeship. I recently wired my first transformer and I understand that the neutral and ground are bonded together in the transformer or in the service. What I don't understand is, if the neutral is a current carrying conductor, which is then bonded to the ground conductor, why does current only flow back to its source and not on the ground path...
