How can we improve our robot's ability to pick up cubes at any angle?
  • Thread starter Thread starter cam875
    Angles
To improve a robot's ability to pick up cubes at any angle, a funnel structure can be implemented to guide the cubes into position, using angled rods or bars. This approach simplifies the design and enhances efficiency compared to more complicated solutions. A bucket loader design is also suggested, especially if the competition floor arrangement is unpredictable. Ensuring the robot can approach cubes from various angles will maximize its effectiveness. Adopting these strategies can significantly enhance the robot's performance in cube retrieval tasks.
cam875
Hello, for a school project we are constructing a robot to pick up defined size cubes but the sucker that pulls up the cubes off the ground is made of rubber gears that spin and suck them up. It works pretty good, but only when the robot is perfectly lined up on the cube, and I am wondering what kind of structure could we use inorder to come up on a cube and pick it up on any angle that we approach it, inorder to be as efficient as possible.
Thanks in advance
This may not be the answer your looking for but I would use fire to melt the ice cubes and then some type of vacuum mechanism to suck up the water.
Hmmm... I didn't see anything about ice in that post.
I'd start with a 'funnel' that will channel the cubes into position. Just a couple of rods or bars sticking forward at an outward angle on both sides of the pick-up point should do it.
Did something similar for B.E.S.T. in HS. If you are using a complicated solution and only getting mixed results it's time to go with something simple.
I would recommend a bucket loader design unless you are guaranteed a certain arrangement on the competition floor.
Thread 'Turbocharging carbureted petrol 2 stroke engines'
Hi everyone, online I ve seen some images about 2 stroke carbureted turbo (motorcycle derivation engine). Now.. In the past in this forum some members spoke about turbocharging 2 stroke but not in sufficient detail. The intake and the exhaust are open at the same time and there are no valves like a 4 stroke. But if you search online you can find carbureted 2stroke turbo sled or the Am6 turbo. The question is: Is really possible turbocharge a 2 stroke carburated(NOT EFI)petrol engine and...
I need some assistance with calculating hp requirements for moving a load. - The 4000lb load is resting on ball bearing rails so friction is effectively zero and will be covered by my added power contingencies. Load: 4000lbs Distance to travel: 10 meters. Time to Travel: 7.5 seconds Need to accelerate the load from a stop to a nominal speed then decelerate coming to a stop. My power delivery method will be a gearmotor driving a gear rack. - I suspect the pinion gear to be about 3-4in in...
