Radian Measure and the Unit Circle
Radian measure is defined as the angle subtended at the center of a unit circle, with a full circle measuring 2π radians or 360 degrees. A right angle corresponds to π/2 radians, while a straight angle measures π radians. To convert degrees to radians, multiply by 2π/360, and to convert radians to degrees, use the inverse fraction 360/(2π). Understanding these relationships helps clarify the connection between radians and degrees. This foundational knowledge is essential for mastering the unit circle and trigonometric calculations.
Sean Cook
I need some guidance into understanding Radian Measure and the Unit Circle. This was the topic where I tanked and had to drop the course. I'm going to pick it up again next fall and want to start preparing now.
Any help is appreciated.
Sean
What, exactly, do you want to know? "Radian Measure and the Unit Circle" is a wide topic!
Essentially the idea of radian measure is that it IS the circumference around a unit circle cut off by an angle at the center. In particular, since a circle of radius 1 has total circumference of 2\pi, radian measure in a circle goes from 0 to 2\pi. A right angle cuts off 1/4 of the circle and so its measure is 2\pi/4= \pi/2 radians. A "straight angle" cuts off 1/2 the circle and so its measure is 2\pi/2= \pi radians.
That makes a lot more sense to me than the way is was explained, but it leads to my next trouble spot. How is a radian measured in degrees? This was where I was told to think of it like a "Clock" and that confused me and was unable to perform the calculations.
Sean
A complete circle is 2\pi radians or 360 degrees. You can think of that as "2\pi radians per degree" or
\frac{2\pi \text{radians}}{360 \text{degrees}}[/itex] So to go from degrees to radians you multiply by 2\pi/360 degrees to &quot;cancel&quot; the degrees and get radians. That is 90 degrees is (2\pi/360)(90)= \pi/2 radians.<br /> <br /> Going the other way, you just invert the fraction:<br /> \frac{360}{2\pi}[/itex].&lt;br /&gt; &lt;br /&gt; \pi/3 radians corresponds to 360/(2\pi)(\pi/3)= 360/6= 60 degrees.
Thank you for explaining it this way, with the examples as well. I think I actually have a better understanding now :-)
I tried to combine those 2 formulas but it didn't work. I tried using another case where there are 2 red balls and 2 blue balls only so when combining the formula I got ##\frac{(4-1)!}{2!2!}=\frac{3}{2}## which does not make sense. Is there any formula to calculate cyclic permutation of identical objects or I have to do it by listing all the possibilities? Thanks
