If I could travel close to the speed of light
sodaMay
Say I was embarking on a journey to Neptune at 95% the speed of light.
Neptune has a minimum distance of 4.3 billion km from Earth. If I was traveling at 2.85 x 108 m/s, I would take 4 hours 11 minutes and 38 seconds to get there. Is this even possible?
1)What would I see of my surroundings, would I be able to see anything at all?
Would I be able to see anything at all, since I'm traveling close to the speed of light?
2)Would I have any communications difficulties?
Since I'm traveling at such an insane speed, I would encounter time dilation, which would make communications with Earth difficult because we are in different time references, right? And will the Doppler effect affect me as well?
3)What relativistic effects (time dilation, aging - twin paradox, etc.) will I face?
Could someone elaborate on this because I really can't grasp this concept of time dilation and the twin paradox thing.
4) What happens on my return journey?
Leaving aside the incredible amount of energy required to accelerate you to such a speed and the decelerate once you got to Neptune (great destination) the 4hr11min38sec journey time is measured by whom? You are in the time dilation zone so for you the measured journey time will be a bit less.
On the Web you should be able to find visual examples of the distortions you would see traveling at such a speed.
If you were shining a light out of the rear porthole of your spaceship would it look bluer or redder than usual to someone observing it from Earth?
##|\Psi|^2=\frac{1}{\sqrt{\pi b^2}}\exp(\frac{-(x-x_0)^2}{b^2}).## ##\braket{x}=\frac{1}{\sqrt{\pi b^2}}\int_{-\infty}^{\infty}dx\,x\exp(-\frac{(x-x_0)^2}{b^2}).## ##y=x-x_0 \quad x=y+x_0 \quad dy=dx.## The boundaries remain infinite, I believe. ##\frac{1}{\sqrt{\pi b^2}}\int_{-\infty}^{\infty}dy(y+x_0)\exp(\frac{-y^2}{b^2}).## ##\frac{2}{\sqrt{\pi b^2}}\int_0^{\infty}dy\,y\exp(\frac{-y^2}{b^2})+\frac{2x_0}{\sqrt{\pi b^2}}\int_0^{\infty}dy\,\exp(-\frac{y^2}{b^2}).## I then resolved the two...
Hello everyone, I’m considering a point charge q that oscillates harmonically about the origin along the z-axis, e.g. $$z_{q}(t)= A\sin(wt)$$ In a strongly simplified / quasi-instantaneous approximation I ignore retardation and take the electric field at the position ##r=(x,y,z)## simply to be the “Coulomb field at the charge’s instantaneous position”: $$E(r,t)=\frac{q}{4\pi\varepsilon_{0}}\frac{r-r_{q}(t)}{||r-r_{q}(t)||^{3}}$$ with $$r_{q}(t)=(0,0,z_{q}(t))$$ (I’m aware this isn’t...
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
