Inputting tan-1(-5/2) on a Calculator
  • Thread starter Thread starter dankelly08
To input tan-1(-5/2) on a calculator, use the specific key for the negative number, typically marked as "(-)" rather than the standard minus sign. For the inverse tangent function, look for a key labeled tan-1, atan, or arctan, often accessed by pressing a secondary function key. It's important to understand that tan-1 is a single function and not to be confused with exponentiation. Many users find this distinction confusing, leading to frustration when trying to perform calculations. Properly using these keys can simplify the process significantly.
dankelly08
how do you type in,
tan-1(-5/2) (or any negative number)
on the calculator?? or just work it out?
Mathematics news on Phys.org
Are you talking about the (-5/2)? Most calculators have a separate key for that, which usually has something like "(-)" printed on it (a short dash in parentheses), rather than the normal (longer) minus sign "{}-{}".
If you are referring to the -1: there should again be a separate key. On my TI calculator it is Second + Tan, just find where is says tan-1, atan, arctan, or something like that. Note that you should consider "tan-1" as a single function, it's not something like x-1 = 1/x, for which you can write in general x-n = 1/xn. Instead, it is defined by tan-1(tan(x)) = x.
Yeah I got it, thanks alot! it was(+/-)
I spent a full hour trying to figure that out lol..:redface:
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Suppose ,instead of the usual x,y coordinate system with an I basis vector along the x -axis and a corresponding j basis vector along the y-axis we instead have a different pair of basis vectors ,call them e and f along their respective axes. I have seen that this is an important subject in maths My question is what physical applications does such a model apply to? I am asking here because I have devoted quite a lot of time in the past to understanding convectors and the dual...
